Question about Lands Phones
Number pad does not work properly
Numbers on key pad do not always work
Coldcut
  • 1554 Answers
SOURCE: Number Pad not working
I would try re-seating the keyboard cable
http://www.priorityelectronics.com/images/pop_3f4800ef5205420fabcba8488924da5b.jpg
notice 2 screws at top holding the keyboard.
Posted on Feb 20, 2008
  • 242 Answers
SOURCE: Blue numbers
Make sure Num Lock is on (the light belonging to numlock is on).
Then use Fn + Keys with a blue number on it to use the keypad.
Make sure you hold the fn-key, for each number you want to type...
If this doesn't work, try Fn + Esc. If your laptop goes to standby mode, The Function key is allright, and there is another problem. If it does not work, your keyboard may not be installed probably, or may be defect.
Please post some feedback,
Good luck
Posted on Apr 04, 2008
SOURCE: Number pad on iMac keyboard inactive
Press "clear" on the numbers pad, then the numbers will type.
Posted on Feb 01, 2009
  • 103 Answers
SOURCE: where to get new key pad
you need to pull it a part and cleen the push butons under the carban with matho cheers peter
Posted on Apr 05, 2009
Geekman
  • 32281 Answers
SOURCE: number keys on think pad lock using openoffice.org
On Thinkpads laptops the keys on the right hand side double up as the number keypad. To switch on the Number lock key pad on - press and hold the Shift key and press the NumLk/ScrLk key, it is above the F11 key, the Num lock LED will also light up. Press these keys again to turn off the Numer Lock.
Posted on Nov 10, 2009
How to work key pad
Key pad? Do you mean the keyboard or what?
Mar 21, 2016 | Dell Inspiron 1525 Notebook
Lately I've been always getting the following error "10086 - Error Invalid Number......."
your number input is wrong or maybe you have a key pad error.CONTACT SAMSUNG TECHNICAL
Sep 14, 2015 | Samsung Glaxy SII i777
I have a MSI CX480.Its keybord not working properly.When i type letters i,o,p,l,k,j,m, numbers are coming.Also my delete key is not working. The main problem is when i turn on the computer, it...
NUMBER LOCK
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock.
Nov 27, 2012 | Computers & Internet
My key bord U,I,O,P,J,K,L,M. keys not working when i press these buttons numbers showing plz tell me wich key i press that these keys work properly
You have press the NumLk key (number lock) and this changesthe right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock).it is near the F12 function key. When the NumLk has been enabled a LED light is turn on toindicate this function has been selected.b>
Apr 04, 2012 | Acer TravelMate Computers & Internet
My number pad on my keyboard is not working, how can I reactivate it?
At the top, left corner of the number pad, there should be a key that says "Num Lock." This key toggles the functionality of the number pad keys between Numbers and Directions.
Press Num Lock once and the numbers should start working again.
Press it again, and the keys should go back to the Directions (up, down, left, right, Page Up, etc.)
Jan 11, 2011 | Gateway Computers & Internet
Key pad doesn't register all numbers when pushed. Repair or replace?
The problem of sticking or non-functioning keypad numbers is usually caused by liquid getting in the keyboard circuit.
Although the phone can be disassembled and cleaned, and begin working again, it doesn't mean that the keypad will continue to work properly in the future. It's almost always a continuing problem.
My recommendation is to replace the phone. I've seen this happen too many times in the past to recommend otherwise.
Feb 02, 2010 | Motorola Mobility RAZR V3
Nokia N73 number 2 key not working.
hell there! I want u to try this small antidode get the key pad membrane cleaned which is under the key pad . coz some kind of carbon forms after a period of time or liquids to can cause this too.
lastly if no change change the key pad membrane .
Get a technician to do this for u
have fun
good luck
Sep 08, 2009 | Nokia N73 Cellular Phone
The keyboard has a keypad, but when y turn on the num lock, the letter keys will also start working as a keypad. My computer is an HP Pavilion dv9730us Notebool PC. It has a full keyboard, with a keypad...
Sorry but you found what is NORMAL for laptops. this is not a bug, error, fault, etc.
It does exactly what it is supposed to do even though it may have a proper number pad too. leave num lock off
Aug 09, 2009 | HP Pavilion dv9730us Notebook
Turn off touch pad
When you are booting up from a cold shutdown, Tap the F2 key until you enter the Bios/System Setup Pages. Usually you use the Alt+P key combination to navigate in these pages, but there should also be a legend at the bottom of these pages to indicate what keys change pages. In these pages you will come upon your option to choose pointers. One is usually, glide pad + mouse. I'd try that first, as it senses when a mouse is attached and disables the glide pad. However, this doesn't always work with Dells. So, if that is the case, choose Mouse Only for a PS2 Mouse and or Serial for a USB Mouse.
The Glide Pad is found in the Control Panel, Mouse where you have a property tab that has the settings for your glide pad. Besides setting pressure sensitivity you can also disable it in some Dell Systems.
If none of this works for you, look on the bottom of your laptop for the Service Tag number and send that set of numbers and letters to me using the comment box below and I'll find you the driver update that should repair your Glide Pad.
As always, please rate all our solutions on FixYa.
Always here to help,
Worldvet
Aug 21, 2008 | Computers & Internet
Garmin nuvi 350
You can recalibrate the touch pad. It's in one of the setup menus I think.
Nov 19, 2007 | Apple iPhone 3G
Lands Phones Logo
42 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
