Question about Audiovox AVP-7000 Video Cassette Player - 12 Volt Car Video Player
THE VHS TAPE WILL NOT INSERT IN PLAYER - Audiovox AVP-7000 Video Cassette Player - 12 Volt Car Video Player
Have unit hooked up, but cannot get the vhs casset tape e to remain in player, keeps ejecting.
Typically a VHS tape has a button on the underside that unlocks when pressed inside the VHS player. The wheels unlock and move the tape in the VHS. If this doesn’t happen, the tape will eject.
Oct 26, 2017 | Televison & Video
I put the VHS tape in and all I see is fuzz I can here the movie
VHS tapes have two tracks One a Video and the other Audio. The read Heads align with these tracts and transmit the data to the appropriate electronic converters; one is the Audio Amp. and the other the Video Controller. If one or the other is defective or coated with material transferred from the surface of the tape; that magnetic head cannot pick up the data.
The first thing to do is Clean the Heads. With a cue-tip saturated with rubbing alcohol; (Not dripping wet) gently ride back and forth over the magnetic head inside of the player. Do this a few times until there is no sign of blemish on the surface and when DRY, insert a tape and see if that fixed the problem. Often time...the OXIDE from a tape collect on the heads and must be removed. This cleaning method will NOT hurt the player at all. Just be certain to Unplug the player when doing this proicess.
Dec 23, 2013 | Emerson Dvd/vcr Combo Player Vhs
Hi8 insert tape
I don't believe there are hi-8 adapters, only VHS-C to standard VHS... are you looking for a hi-8 player?
May 09, 2013 | RCA VCA115 VHS-C Adapter
My Panasonic VHS Player Model PV-V4020 is locked up so I cannot insert a new tape.
This will be some form of physical damage to the carriage mechanism, that holds the tape. Sometimes it's a simple thing like the flap getting stuck. But often it's a broken piece of plastic.
Apr 21, 2013 | Televison & Video
Sony vhs will not record
hello
does it not record from dvd? did you check from external source to record? is the vhs tape you insert for recording record protected (small plastic lid broke out to prevent recording)?
Feb 09, 2011 | Sony SLV-D370P DVD Player/VCR
Tape stuck in vhs players
Yes you can cut the tape, remove it and then go to radio shack or walmart electronics dept and get some special vhs repair tape.
Apr 27, 2009 | Sony SLV-D300P DVD Player/VCR
How To Burn a DVD from VHS tape
Insert the VHS tape. Do not press play. Insert a DVD RAM or DVD-R into the DVD side and press and hold DVD DUBBING, it should start playing the VHS immediately while recording on the DVD side.
Jun 03, 2008 | Panasonic DMR-E75V DVD Player/VCR
Record from VHS to DVD
i should imagine so if they are not copy protected films i.e shop ones .if they are tv films on tapes etc then it would be possible to do so.
via insert the vhs tape and insert the blank dvd in to its tray
play the vhs tape and press rec to record on to dvd .
although the manual might give a better guide to doing this .
Online User Manual and Guide for Samsung DVD-V4600 DVD Player / VCR Combo by FixYa, Page #1
riz.
Mar 26, 2008 | Samsung DVD-V4600 DVD Player/VCR
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Audiovox AVP-7000 Video Cassette Player - 12 Volt Car Video Player Logo
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
