Question about Dewalt DC011 AM/FM Radio
Only works with battery, wont charge no sign of power. fuses are fine
  • 2 more comments
  • Anonymous Jul 05, 2008
    120vac/14vdc Transformer primary is open. Accidentally pluged into 240v. Need price and supplier.
    Carl Weinfurter
  • carlew Jul 05, 2008
    120vac/14vdc transformer has an open primary. Need Price and supplier.
  • Anonymous Jul 27, 2008
    How to you get case open to get to fuses? I took 8 screws out still wont open
  • hamma22 Sep 22, 2008
    radio only works with a battery. will not charge battery or play radio using the cord. i took the back off and the radio has power running to the circuit board, after that i don't know what happens.
  • 1 Answer has all parts for the DeWalt radio
Posted on Sep 06, 2008
  • 313 Answers
Circuit board location in left maybe gone
Posted on May 29, 2008
Ive got the same problem checked resistors and circuit boards cant figure out .let me know if you find out whats wrong
Posted on Feb 04, 2008
Transformer is bad.
Posted on Feb 28, 2008
Zte n9510 will not turn power up
There different thing you could try to pinpoint the problem.
1. Is the battery good? Make sure that battery is charging correctly.
2. Is the charger working fine? If there is any doubt, try to borrow one from a friend.
3. If the battery and charger are fine, when you connect the charger, does it give you any sign of life? Any light or display? If not, then your phone is either brick or dead.
Mar 24, 2014 | ZTE Cell Phones
My pmid705 wont charge for some reason and the battery is 35% the battery was just working yesterday (date March 20,2013
You have to check if the charger is still working fine. Check for any sign of power. You can also try removing the battery and use the charger in supplying the power to your computer, if it does not work then it's your power cord that's causing the problem and you might want to replace it.
Mar 21, 2013 | Computers & Internet
1995 dodge intrepid wont start. Battery is fully charge but no power to anything. Car wont start
The alternator would not come into play unless the battery was dead.
Could be corrosion inside one of the battery cables, or a blow maxi fuse for the fuse box. Or a bad ground connection.
You would need to take a meter or test light and check for power at the starter post, and the major fuses.
Dec 22, 2012 | 1995 Dodge Intrepid
New battery. abs, battery and service engine lights come on. all headlights and tails flicker and car dies and wont start. jump it let it warm up and doesnt do it for awhile. then at some point it does it...
These are all signs of a bad alternator. The car is running off of only the battery. The alternator charges the battery and keeps the car running. When the alternator quits charging the car will run fine until the battery dies. Then you can jump the battery and charge it, and the car will run fine until all of the electronics and lights run the battery down again.
Jan 25, 2011 | 2000 Pontiac Grand Prix
My psp wont charge. The battery went flat and now it wont charge. i have tried it on the mains and through my pc.
Hi it would be the fuse on the circuit board or the pin in the charge plug loose look for diagramme for fuse thru google for your model or replace the power charge cable which ever the problem The fuse you need soldering skills and a fine soldering iron or mabee its the battery try to charge it in a friends first. 1xxx will fit into a 2xxx but not visa versa
Mar 16, 2010 | Sony PlayStation Portable (PSP) Console
Everything works great..However periodicaly radio wont work than battery dead after sitting for sometime.If i pull audio fuse [thats not blown]and re install fuse radio is fine and battery stays...
the radio is pulling down the battery, check to make sure it is install properlt, also make sure your battery is not weak, because remember the radio draws power at all time, to keep the time and your preset radio station. so check the battery for proper strenght first please.
Jul 31, 2009 | Hyundai Santa Fe Cars & Trucks
T20 wont turn on
make sure the battery is unplugged from the laptop and only hook up the ac adapter. If you can't get it to turn on then try anotherr knowng good working adapter and if it still can't turn on then the motherboard is bad and will need to be replaced.
Jul 06, 2009 | IBM ThinkPad T20 2647 Notebook
1993 cutlass supreme
Are you Sure the Alternator is Fine???? Sounds an Awful Lot like it is not Charging the Battery to Full Capacity.
Jan 22, 2009 | 1993 Oldsmobile Cutlass Supreme
I have Canon power shot S2 IS digital camera.I bought it around 2 years back.Now my camera is showing the sign of "change the batteries" even though the batteries are fully charged and the lens does not...
i suggest replacing a fresh battery will most likely solve your prob, overtime rechargeable battery can drain easily, try changing with a new battery and see if it does work well, there might be insufficient current, thats why it tends to drop of voltage easily upon using,
there is a specified lifetime for rechargeable battery, depends on your usage and charging method, theymaybe fully charged but sometimes wont give you enough power to drive
Nov 26, 2008 | Canon PowerShot A540 Digital Camera
Dewalt DC011 AM/FM Radio Logo
940 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rob Beech
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
