Question about Dell 962 Photo All-In-One InkJet Printer
My printer says incorrect port detected - Dell 962 Photo All-In-One InkJet Printer
    President:
  • 3,278 Answers
Hi, Malcolm.
Boot your system to Safe Mode (press F8 repeatedly).
Login as Administrator (no password).
From the Control Panel, click on Printers & Faxes.
Right click on the Printer and select Properties. In the Advanced tab, tell it to Print Direct to Printer instead of using the Spooler..
It's a problem often seen on XP Home where a Symantec product (like Norton A/V) is installed.
Hope this helps.
Posted on Oct 05, 2009
4 Suggested Answers
samuelseno
  • 103 Answers
SOURCE: My lexmark 4300 series says incorrect port detected
Hello!
Yes the problem is with your printer port setting, to view or to correct the printer port setting,
- go to CONTROL PANEL
- click or open Printer or Faxes
- right click your Lexmark printer and click properties
- a menu will appear, choose or click PORT tab
- at the Port tab listing, choose USB port and click ok after choosing the right port.
then you should be able to print properly after the right configuration.
Hope I was able to help.
Posted on Jul 23, 2010
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: haveing problems with x8350 printer,will
    Try to disconnect the printer from your computer. Reboot your computer. Unplug and replug your printer into the power outlet. When the printer turns on, reconnect it to your computer. Doing this usually fixes minor communication issues. Check and try to print again.
    Posted on May 11, 2011
    hemantraj
    • 638 Answers
    SOURCE: Incorrect Port Detected
    1. FIRST TRY TO CANCEL ALL THE PENDING DOCUMENTS WHICH YOU HAVE GIVEN BEFORE THEN TRY TO PRINT IF THIS DOES NOT WORK THEN TRY OTHER OPTION GIVEN BELOW.
    2. CHANGE THE USB WIRE (THE CONNECTION BETWEEN PRINTER AND YOUR PC )IF IT IS TOO OLD.
    3. THERE MAY BE THE PROBLEM WITH USB DRIVERS IN UR PC .
    4. TO RECTIFY --- RIGHT CLICK THE MY COMPUTER ICON
    5. CLICK PROPERTIES AND THEN CLICK HARDWARE N GO TO DEVICE MANAGER
    6. UNINSTALL ALL USB PORTS AND THEN SCAN FOR HARD WARE CHANGES
    7. UR PC WILL DETECT UR PRINTER N ASK FOR PRINTER DRIVERS
    8. RELOAD DRIVERS N UR PC WILL COMMNICATE WITH UR PRINTER.
    9. FOR FURTHER ASSISTANCE FEEL FREE TO ASK AND WISH U SUCCESS -BYE
    Posted on Jun 08, 2008
    I am getting an error message saying Incorrect port detected. The printer is designed to work with USB cables only. The current software setting is not set to USB port. In my printer properties dialog
    Do you hear the connect/disconnect sounds when you plug the USB cable into your computer? If you do not, then the system is not recognizing the printer USB port.
    Here is what I would do:
    1. In the Devices and Printers section of the control panel, right-click on the printer icon, and select printer properties, then select the Ports Tab. Delete any ports connections for the printer. There could be several for the same printer.
    2. Uninstall all Lexmark drivers.
    3. Make sure that the printer does not show up in the Devices and printers under control panel. If the printer still shows up, remove the device by right-clicking on the icon, and select Remove device.
    4. Reboot the computer.
    5. Re-install the printer software. The software should detect the printer on the USB port.
    Good luck.
    Alex
    Feb 14, 2015 | Lexmark X5650es All-In-One Inkjet Printer...
    Incorrect port detected on 2600
    It could be that the port for the printer in the Control Panel is not configured correctly. You may refer to this article on No Communications Error When Trying to Print or Scan. If that doesn't help, I would suggest you uninstall the Lexmark software. Download the updated Lexmark X2600 driver (Windows only) from the Lexmark website at http://bit.ly/aNGYmW. Select your operating system to download the driver. Thanks.
    Jan 18, 2011 | Lexmark X2600 InkJet Printer
    Hello!
    Jul 23, 2010 | Lexmark All-in-One Printer with PictBridge
    Lexmark X 4550 scans ok but when i try to print, "incorrect port detected" comes up as a fault, i have it all connected ok and in a usb port. can anyone help please.
    look under control panel ,printers and faxs, right mouse click on your printer displayed in the list , then from the list, select properties . Next from the tabs on top , select ports, from the ports list select the usb connection on the list or if wireless you should have a lexmark connection port showing as well. Its just you havent got the correct port selected.Dave
    Jun 06, 2010 | Lexmark X4550 InkJet Printer
    Lexmark Z35: Problem Communicating with the
    Installing like this Lexmark are Plug in Play, Windows automatically detected such devices connected on it. If not then try to use another USB Connector to see which is the problem occur or might be your printer too...
    Oct 04, 2009 | Lexmark Z735 InkJet Printer
    According to Features and Specs on Lexmarks website, this is a All in One? i.e Fax, Printer, Scan & Copy? also it's a Network type?
    If so have you chosen the correct settings via the Printers Dispay and Control Panel? ...... I assume you have and everythinh in Device manager looks good, i.e no Yellow and or Red Icons over anything listed there, especially USB....correct?
    If your Vista is the 32 Bit then the driver file should be: cjb5000enOSS.exe (87.7MB)
    If Windows Vista x63 then it will be: cjq5000enOSS.exe (132.76MB)
    Hope the above helped,
    cheers,
    Bastian
    Jun 02, 2009 | Lexmark X5075 InkJet Printer
    Incorrect port detected 926
    Try reinstalling the drivers for your printer. You should have a disk that came with the printer. If you don't then you will have to search the Dell website for the drivers. Once you have found them, reinstall them and see how that works out.
    Let me know wether this helped or not.
    Feb 11, 2009 | Dell 926 All-In-One InkJet Printer
    Help
    sounds like the settings for your printer are unhappy. try a re installation
    http://tinyurl.com/6qcpgy
    Aug 19, 2008 | Lexmark X6170 All-In-One InkJet Printer
    Jun 08, 2008 | Lexmark X3550 All-In-One Printer
    Dell 962 Photo All-In-One InkJet Printer Logo
    1,023 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    Electro Med Services...
    color wheel light...
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
