Our TV went out. It start just shutting off and
Our TV went out. It start just shutting off and now it will not come on....is this a common problem? it is a 52 in RCA rear projection
  • 5,138 Answers
Need your Model and Chassis number in order to help you.Most common problem is FBT flyback Transfomer 239111#
Posted on Oct 05, 2009
I have a sony model KP-48V90 All of the sudden the picture started ghosting and the color went green and redish haze
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
To get fixed either call in a local TV repair company or goto sites such as www.TvRepairKits.com to get a repair kit with instructions.
Oct 14, 2010 | Sony Televison & Video
Projection TV Phillps 60PP9202/17F, bought 2004. Was watching and suddenly the picture went out. All connections are good and components work. Can you help?
Hi.
If there is no power at all, then it is either the power cord or power board inside the TV.
If after the fault the TV went in standby and does not wake up, then the TV is in protect mode.
In protect mode higher voltages from PSU gets shut down and TV remains in standby.(see also Why my TV does not start up and remains in...)
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Then connect powr
If that does not work, and you keep having the TV in protect mode, it means that there is a fault.
In that case call the support number listed on Philips user manual to arrange repair.
If you are a technician I can try locating parts, service manual and giving more directions. Common faults that affect a Philips rear projections are convergence, PSU board, lamp and ballast assembly.
Regards.
May 28, 2010 | Philips 60PP9202 60" Rear Projection...
My Samsung HL-P5063W set turns off on its own randomly. Set is 5 years old. This started after I went on the AT&T Uverse service, but that may be coincidental. The Uverse box and service stay on, but...
First thing change the lamp. There are several other things but this is most common. Be sure tab on lamp door presses door switch in downward position when you change the lamp. MCM Electronics you can get a philips bulb for $99.00.
Nov 29, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
When powered on, automatically shuts off with red flashing light.
you can claim the repair on your home insurance policy as FUSION
Sep 13, 2009 | JVC AV-27920 27" TV
Im on the tv, the screen shut down few minitues.
It sounds like the tv went out and needs to be repaired. Common causes are a bad power supply, circuit board, or power control board.
May 14, 2009 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Car keeps shutting off
try replacing the crankshaft position sensor - it's a common problem on the 88's and is only about a $30 part
Sep 07, 2008 | 1994 Oldsmobile Eighty Eight
I have a problem
I've heard this is a very common problem with the 88's, and the best research I've found so far suggests that you should replace the crankshaft position sensor - it's only about $30, but requires a little work.
Shutting down....
You have POWER supply board that went out.....apparently this is a common thing for this model.....sorry to see such low activity on this site......hope it helps.....
Apr 13, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
