Question about Cameras
Everytime I turn on my camera, it says please reinsert memory stick.I have done that and have tried everything but it still has that message and won't take pictures. HELP!
jackboy
  • 2985 Answers
SOURCE: Reinsert Memory Stick Message
This could be a memory stick contact problem- do you have access to another stick[without actually buying one] to which which is at fault -stick or camera - your friend local camera store perhps
Posted on Jul 31, 2007
  • 74 Answers
SOURCE: Reinsert the memory stick...
you will need to re formatt the card and this problem should be solved
Posted on Aug 12, 2008
hichama9
  • 65 Answers
SOURCE: have a DSC-S930 camera inserted my memory stick
Hello Mate,
you may double check how you inserted the memory stick, it may be in wrong position.
other than that, you can insert this memory stick into your computer and see if you can open it from there. and you can also format it from your computer and then test it again with your camera.
Best Regards,
Posted on Oct 31, 2009
  • 411 Answers
SOURCE: reinsert memory stick
contacts of the memory stick clean it
Posted on Mar 01, 2010
SOURCE: Error message: Reinsert the Memory Stick"
The problem is with the memory card. It probably just shorted internally and is no longer useful. The amount of memory is not the problem, as I used a 4GB card for a long time and my card finally went bad. You will just have to get another memory card and MAYBE find someone to be able to retrieve your data.
Posted on Jul 05, 2010
Sony cybershot H-55 shows 'NO MEMORY CARD' message
The sony cameras are very picky on memory cards. They only work with the some types memory stick duo. But if the card already did work in your camera, you should check the contacts on both the memory stick and in the camera. You also need to check if you did not try to put it in the wrong way around. It should not be possible to reverse the memory stick, but if you don;t know your own strength damage on the memory stick and camera can be done.
Please if possible try to read the memory stick in the card reader on your PC. and look if you did not damage the contacts on the stick and in the camera.
Jan 06, 2014 | Sony Cameras
How to fix "reinsert memory
Welcome to FixYa.
There 3 possible causes why do you received an error message " reinsert memory card"
Cause
1 The inserted Memory Stick media is not supported for use with the camera.
2 The terminals on the Memory Stick media are dirty.
3 The Memory Stick media is damaged
Resolution
1 Ensure you are using the supported type and capacity of Memory Stick media for use with the camera
2 Use a clean pencil eraser and lightly rub the Memory Stick terminals to remove any oxidation or dirt build-up
3 Use different Memory Stick media
I hope this steps wil help you to resolve your isuues.
Thank you for using FixYa.
Apr 04, 2011 | Sony Cybershot DSCW310 Digital Camera
Hi I have a sony cyber shot camera when i tried to ON it The memory stick error appears saying " INSERT MEMERY STICK" inspite of memery stick is inserted also i get this error.And when i tried to format it...
The Reinsert Memory Stick error message appears when the inserted Memory Stick is corrupted or not in a correct Format. This issue can be resolved by trying the steps mentioned below:
  • Remove and re-insert the Memory Stick in the Camera.
  • Check if the inserted Memory Stick is compatible with the Camera.
  • Format the Memory Stick in the Camera. Do not Format the Memory Stick in the Computer, as this will damage the Memory Stick being used in the Camera. The Camera will not detect the Memory Stick again, if it is formatted in the Camera.
  • Clean the terminals of the Memory Stick by using a soft dry cloth.
  • Remove the Memory Stick from the Camera and check if the Internal Memory is working fine.
You may also try power resetting the Camera. Power resetting can be done by removing the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Oct 21, 2010 | Sony Cameras
Reinsert memory stick
Mar 01, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
Keep getting message to reinsert memory stick!!!! Help!!!
I have a Sony Cybershot DSC T70 and it keeps saying "Reinsert memory stick" whenever I turn on the camera or slide down the camera lid. Also, whenever I try to view the pictures on my laptop it shows "Please reinsert the memory stick" something along those lines. As I have been researching for the solution, I would have to format the memory card. However, I wouldn't want to lose the pictures as I just took many as from the holiday last week. The only problem is the memory card, I tried using another memory card and it works fine with the camera. There is nothing wrong with the camera.\r\nCan someone please help me how to solve the memory stick problem? It would be great. Ty.
Oct 16, 2009 | Cameras
I have this message on my sony digital camera:"REINSERT THE MEMORY STICK" why?
Oct 10, 2009 | Sony Cyber-shot DSC-W190 Digital Camera
Will not allow me to view pictures I just took
Try to recover what is left on the memory stick with TestDisk on a pc.
Note, download the windows version and not the dos/windows version, the
dos/windows version is for windows 3.11 and lower.
http://www.cgsecurity.org/wiki/TestDisk_Download
Try to fomat the card afterwards if this does'nt help at all try another card in
your camera, if the other card works replace your other card else get te camera autorized repairs man.
Succes.
Aug 28, 2009 | SanDisk 4GB Memory Stick PRO Duo Memory...
Aug 09, 2009 | Sony Cybershot DSC-S950 Digital Camera
Keeps telling me to reinsert my memory stick
I will forward a link to a page where you can get the information about this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C166567
Also please check whether you're using a Compatible Memory Stick with the Camera.
It's not recommended to Format the Memory Stick in the Computer.
The Memory Stick should be Formatted in the Camera only, other wise such error messages can occur.
Please try using a different Memory Stick and check whether the issue persists with the other Memory Stick.
This is to check whether the issue is with the Memory Stick.
Apr 14, 2009 | Sony Cyber-shot DSC-W300 Digital Camera
Memory stick error
your memory card has a virus! try formatting using camera. make it a habit that whenever you reinsert the memory card in your camera format it first before taking shots, this will erase everything including virus!
Sep 14, 2007 | Sony Cyber-Shot DSC-P200 Digital Camera
Cameras Logo
59 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
