Question about Panasonic VIERA TH-65PV500 65 in. Plasma Television
Why my red led blinks 10 times and then repeats itself. i have a panasonic px60 screen
  • richard729 Jan 01, 2008
    My TH50PX6U went out on New Years Eve. I thought I heard a popping sound right before the screen went blank. The sound from the speakers still works. Even after unplugging the TV the red power light still flashes red ten times in succession. I held the power button in for about 10 seconds and then released it but it resumed its 10-second flashing sequence.
    This set is about 9 months old and is still under warranty but for a unit this new it makes me wonder how good (or bad) the quality is for Panasonic.
    From what little I've read on the FAQ forums it sounds like the problem could be related to the coolling fan. Funny, my old 27" standard Toshiba worked swell for over ten years without a single problem.
  • dangdog Mar 01, 2008
    Its exactly as was previously written, a loud "pop" blue ball of light and then death. I agree, I saved all summer for this set, along with all the stuff that goes with the purchase and Ive only had it 2 months. My Sony CRT lasted 10 years with not a single problem. In fact while plasma is being fixed Im probably going to be using it again. Oh the irony.
    President:
  • Panasonic Master
  • 1,779 Answers
I know your frustration, all the brands have problems. It sounds like your inverter has gone bad and they do. I've replaced several of them. Try not to compare the new sets with the old. The new sets will not ---will not last nearly as long or as reliable as the old technology. It's sad that you spend at least $1000.00 for a set these days just to have it a throw-away in two years.
Posted on Feb 12, 2008
Panasonic tc p50g15 tv will not turn on tried 1 minute unplug reset and 20 sec power button hold in. Did not work now no led lights
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 17, 2016 | Panasonic Televison & Video
Jake I have a 52 inch Panasonic plasma tv that will only run the fans for a few seconds and shutdown red light blinks 10 times and repeats.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Nov 10, 2015 | Panasonic Televison & Video
NO PICTURE OR SOUND ,GREEN LED STAYS ON FOR 10 SECONDS THEN A RED FLASH . PROCESS REPEATS ITSELF
Hi
You have to check how may time that led flashes. check the link for more details about led blinking in sony bravia tv.
www.electro-medical.blogspot.com
Mar 18, 2015 | Sony KDL-40XBR4 40 in. LCD HDTV
Bought in Dubai 3 years ago Pan.Viera LCD 32"\r\nStandby light flashing red/green. Have to switch on with on/off button after a few minutes switches off itself..........then back on itself
Power LED Blinking timing chart
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
blinking
1 dg board, (stv 5v sense time out)
2 d board
3 d board
4 p board
5 d board
6 su sd sc boards
7 su sd sc boards
8 ss board
9 panel config
10 digi board-
11 pb board
12 h board
13 dg board
Tom Miller
Broadcast Eng
Mar 04, 2011 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
I have a Panasonic PT-50DL54 50" rear projection tv. My tv screen won't come on but the fans will. The power led light flashes green like normal but than starts to flash fast for about a minute than the...
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
Jun 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic TH-42PZ700U Blinking Light Of Death
Panasonic sent a repairman out with the correct part for free, even though the unit was out of warranty. Call 800-524-1448 1 or 800-211-7262
Sep 08, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
http://servicemanuals.vstore.ca/
Oct 12, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
152 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
