Question about Whirlpool RBS275PD Electric Single Oven
Oven light (surface heating) won't turn off
My oven surface heating light is alway on even after I turn off the oven, Could you tell me what is going on?
    President:
  • 1,304 Answers
It is normal for it to stay on until the glass gets below 110 degrees it is for safety reason
Posted on Oct 05, 2009
Gas Pizza Oven - Heat issues
Many of the Pizza ovens require ceramic plates that line the bottom surface of each oven. These ceramic plates absorb the heat and retain the temperature. I never used our ovens with a bare lower surface, always applied the plates for even heat and distribution.
Mar 05, 2014 | Ovens
Help it lights up but no heat.
Dont use it! You need to pull the cooktop and see what is wrong. There is a chance that the circuit for the surface light is the only standing circuit left because the heating element is bad or loose
May 20, 2013 | Ovens
Why the hot surface indicator light always on when I turn off heat.
the hot surface indicator should go off when th temp of the unit has coled off enough to be touched.if it does not turn off then there is a more than likely a shorted wire.
Nov 28, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My Amana gas oven won't heat up gas smell strong
Sounds like a sticking gas valve or a defective hot surface igniter. Open the broiler drawer or remove the bottom cover in the oven compartment. The oven usually has a hot surface igniter or a spark igniter. Turn on the oven and watch for the hot surface igniter to start glowing. It should glow very bright. Once it is glowing the burner gas should come on. If you hear the gas come on it should light right away. If there is any delay shut off the oven and stay back. Let the gas clear out then inspect the area near the igniter and make sure the burner is not plugged(the little holes may have debris in them). If you turn on the oven and the igniter comes,glows brightly,no gas is heard but you can smell gas it is either a blocked burner orfice/assembly or sticking gas control valve. Try giving the burner and gas control valve a tap and see if it comes on. If you tap the control valve and it starts working then shut of the oven and try it several times. If it starts to come on and off now you may have cleared whatever debris was causing the problem. If it does it again then it could be the control valve or a weak hot surface igniter. The igniter can be tested with a ohm meter. Most of the time when I get this complaint it is the oven control valve that is sticking. Be very careful when doing these procedures....gas can build up in the oven compartment very quicky and flash if ignited. Always have the gas shut off valve at the back of the range within reach and the electrical outlet in case you need to unplug it.
Sep 13, 2009 | Magic Chef 9122 Gas Single Oven
THE OVEN WILL NOT HEAT
How old is the unit? Sometimes the igniter can glow but if it isn't drawing the right amount of power to open the gas valve then that is the safety that is built into the oven... So unless the power requirement is meant gas valve will not light. Even though the hot surface igniter is glowing red hot. chances are the igniter is bad. Let me know what turns up. ken
Dec 03, 2008 | Magic Chef 9112 Gas Double Oven
Display is blank, no heat no bake
The oven control panel has failed. For more tech help with this issue and a place to order parts I suggest you go the link below, it is where I go for parts and help. You will need to model number available. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 28, 2017 | GE Monogram ZET3058SHSS Stainless Steel...
No power
First thing to do is pull the oven and check if there is 240 volts going to the oven. The display works off 1 of the 120 volt legs of the 240. If you have the 240 volts, then your issue is with either the display or relay board.
Jan 06, 2008 | GE Profile JTP18 Electric Single Oven
Whirlpool RBS275PD Electric Single Oven Logo
275 people viewed this question
Top Whirlpool Ovens Experts
ashburton
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
