Question about Lexmark C532n Color Laser Printer
Printer is printing lines on side of paper
I have a lexmark C532n. Every time it prints, it puts out a black line on one side of the paper and a blue line on the other side of the paper. I think it has dirty headers, or maybe I am wrong. None the less could someone please help. Thank you.
SOURCE: new printer cartridge in Lexmark 8350; blue lines on pics and papers
In Lexmark printers the ink cartridges can get clogged sometimes. Re-cleaning the nozzles might help fix your problem. Make sure your ink cartridge is not getting empty.
Hope this helps.
Posted on Jul 29, 2008
  • 160 Answers
SOURCE: i am trying to print
yes.it is possible.you will just have to select the legalsize in the printer properties to print on the legal size paper.if not selected the printout will get cut little bit from its end. ok.
Posted on Jan 06, 2009
SOURCE: Lexmark T 640 leaving faint black lines on right side of page
replace your cartridge, and all should be fine.
Posted on Apr 01, 2009
ctf1800
  • 4402 Answers
SOURCE: Lexmark E232 - BLACK SMUDGING on sides of print
try replacing the toner cart. or toner leaked on the area below in which case you will need to blow it out.
Posted on Jun 04, 2009
  • 103 Answers
SOURCE: Lexmark T642 printer keeps printing all pages with
This is due to dust is accumulated on the tufflon drum. Clean the same will resolve your problem.
Revert back for more assistance.
Posted on Jan 28, 2010
My lexmark printer does not want to scan, when we tell it to scan it prints out a paper with blue lines,i have seen this before so i put it in the scanner and it scans that paper but when i put the paper i...
Make sure that you are pressing the Scan button and not the Copy button on the printer operator panel.
Try to re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
Oct 18, 2011 | Lexmark X2350 All-In-One InkJet Printer
Lexmark c532n prints smudges on page
The problem could be caused by the photoconductor units. Try to swap the affected photoconductor units (like swap the magenta with black and cyan with yellow). If problem still occurs, then the photoconductors need replacement. I suggest you contact Lexmark Technical Support for assistance. Thanks
Jul 26, 2010 | Lexmark C532n Color Laser Printer
Lexmark x1270 wont print color even though the cartridge is full.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Next, try this printer self-test by following the steps given below:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know.
Oct 19, 2009 | Lexmark X1270 All-In-One InkJet Printer
I put a new ink cartrige and printer prints low coulour tone.
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark Color JetPrinter 5700 InkJet
Can't print in color
May 26, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
I am trying to print onto legal size paper with a lexmark C532n. Is it possible?
Jan 06, 2009 | Lexmark C532n Color Laser Printer
Blue lines all over the printing
Did u clean the print nozzle's as well? If that does not solve your problem, you should try and replace the cartridge. (Colour in case of blue lines and black in case of black lines)
Jan 22, 2007 | Epson Stylus Photo 1290 InkJet Printer
Lexmark C532n Color Laser Printer Logo
243 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
