Question about Campbell Hausfeld 04 Gallon Twin Stack Compressor HL5502
My air compressors will only build 70 lbs and keeps running campbell hausfeld twin tank
  • 23 Answers
Either the pop off valve is bad or the regulator...Also check for leaks in hoses going to tanks.
Posted on Oct 05, 2009
    Scholar:
  • 53 Answers
Unless you can hear or confirm a leak, your compressor's valve is damaged.
Vt558705 campbell hausfeld sounds like running good but not build up air in tank
Sounds like the compressor itself is bad. If it's an oil-less one, the connector sleeve for the motor and compressor may be bad.
Aug 05, 2012 | Air Tools & Compressors
Builds up air pressure ,motor shuts down
We are distributors of all plastic materials, including complete fabrication of plastic parts, components and assembles like Acrylic sheets, polycarbonate sheet and UHMW.
1)Turn off your compressor or disconnect the power.
2)Remove the connector tube that sends air to the tank.
3)Remove the head bolts on top of the pump.
http://www.plastic-craft.com/novus-plastic-polish-buffing-kit.html
Aug 09, 2011 | Campbell Hausfeld 04 Gallon Twin Stack...
I have a model FP209501 Air Compressor 2 Gallon,
2 gallons is small to begin with u need to buy an in line pressure adjuster/regulator their a few bucks and can be attached to the paint gun or line and will keep the pressure at ur adjustment the regulator on the tank sets the tank pressure at 50 so when u us it will let it drop down to about 45 than start up to build the pressure up to 50 than shuts off than repeats it self the inline keeps pressure steady even if tanks are at 200 psi
Jan 18, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
Campbell Hausfeld extreme duty 4 gallon air compressor, when running won't switch off?
check for a crimped or damaged line going to the presure switch or it might b the presure switch itself
Oct 17, 2009 | Campbell Hausfeld 04 Gallon Twin Stack...
Compressor runs hot and won't build pressure
THE COPPER LINE IS SUPPOSED TO GET HOT, SCALDING HOT ACTUALLY. THE MOST COMMON REASON FOR COMPRESSORS NOT BUILDING PRESSURE IS CLOGGED AIR FILTER OR THE VALVES IN THE HEAD ARE BROKEN OR NOT OPENING AND CLOSING CORRECTLY. YOU MAY POSSIBLY HAVE A BAD AIR LEAK DOWNSTREAM BUT YOU CAN CLOSE THE DISCHARGE VALVE ON THE TANK TO ELIMINATE THAT PROBLEM. HOPE THIS HELPS OR GET YOU STARTED.
Mar 27, 2009 | Campbell Hausfeld Air Tools & Compressors
Does not put enough air in tank
You either have a faulty or out of adjustment regulator.
Mike
Jan 06, 2009 | Campbell Hausfeld 28 - Gallon Air...
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Tank size question
Tank size only becomes a factor for one reason – A larger tank for air. A compressor will run until the pressure in the tank builds to its high-pressure point. Obviously, the bigger the tank, the longer it takes to consume the compressed air. However, the downfall is that once the air is depleted, it takes a lot longer for the air tank to refill with pressurized air. I would only go with the bigger tank if I am concerned about the motor starting and stopping too often, or if I know that I will need a constant flow of air in longer intervals. You have a choice between a larger tank and a constant-run unit.
Aug 27, 2008 | Campbell Hausfeld 04 Gallon Twin Stack...
Campbell Hausfeld 04 Gallon  Twin Stack Compressor HL5502 Logo
239 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
