Question about Frigidaire Dryers
Dryer makes thumping noises - Frigidaire Dryers
  • Frigidaire Master
  • 8,404 Answers
Thuymping noise at start up is normal. the belt gets a kink in it at rest ... just like I do ...
Posted on Oct 05, 2009
How to fix a Frigidaire Gallery Commercial Heavy Duty
Good Morning Friend,
I understand your Frigidaire dryer, model# GLER642A, is making a thumping noise when running, and you want to know how to fix this. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician. They will be able to diagnose your appliance and determine what is causing the thumping noise. Hope this is helpful.
-Best Regards-
WP
Jul 07, 2014 | Frigidaire GLER642A Electric Dryer
My dryer is making a thumping noise frigidaire FAQE7077KR0
You might want to check the idler wheel that takes up the slack in your drive belt. Sometimes the bearings go bad in the wheel and can cause noises.
Apr 20, 2014 | Dryers
Kenmore dryer making a thumping noise
Your dryer has rolls on the drum and they are going bad and need to be replaced
Mar 22, 2014 | LG DLG3788W Gas Dryer
My dryer makes a thump thump sound
  1. Thoroughly check the inside of the dryer for any foreign objects with hard surfaces. Sometimes items that fall out of pockets become stuck inside a dryer and make thumping noises.
  2. Check for level
  3. Make sure the dryer is level. A dryer that is out of level may not rotate properly. Banging or thumping noises from unleveled dryers are common, particularly if the dryer is resting against another metal object such as a washer.
  4. Check rollers
  5. If the thumping noises are present only for the first few minutes of the drying cycle the likely culprit is rollers. If the rollers are warped they will need to be replaced and a professional should be called in to help
Dec 17, 2010 | Frigidaire Electric Dryer
Dryer making sqeaking noise
greetings,
the most likely answer is the belt pulley..the rollers can also make noise,but they usually will make a thump thump noise..remove belt pulley and lubricate and see if this helps
May 17, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Stackable dryer makes thumping noises -think its a broken belt
9 out of 10 times this is due to a bad roller. This is not something you can do yourself. A stack model is just too complicated.
Jun 09, 2009 | Kenmore 84052 Dryer
Lg Gas dryer Dlg0332w drum making noise
The drum on my DLG0332W was also making noise at the back of the dryer...kind of a thump thump thump as the drum rotated. My dryer is only 4 years old. I got brave, downloaded the service manual and opened up the dryer. I found that the drum's welded seam was starting to separate where the roller wheels were coming into contact with the drum at the back of the dryer. Looks like a new drum is in order.
Mar 01, 2009 | LG DLE2532W Electric Dryer
My dryer -model FER311F makes a thumping noise while in use.
Check the 4 feet & make sure top of of appliance is level. These 4 feet will have threaded adjustments, just tilt the dryer back and should be able to turn with your hand or may require pliers, good luck.
Jan 21, 2009 | Frigidaire FEQ332E Electric Dryer
Dryers Logo
125 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
