I have a Lakso model 110 humidifier that needs a filter. Can you advise me where I can find...
(More)
I have a Lakso model 110 humidifier that needs a filter. Can you advise me where I can find one?
Karen Pankratz
pankjp@comcast.net
Hi, Could anyone please recommend filter free cool mist humidifiers (3-4 gallon). I am sick of...
(More)
Hi, Could anyone please recommend filter free cool mist humidifiers (3-4 gallon). I am sick of replacing hard to find filters of my Holmes humidifier.
Thanks.
The water floods in to the bottom and on to the floor Do I need a new washer for the refill...
(More)
The water floods in to the bottom and on to the floor Do I need a new washer for the refill compartment since it leaks out when I fill the tank.
I have a 2-gal Duracraft evaporative humidifier, (DH#803) that I've had for maybe 10 years. Last...
(More)
I have a 2-gal Duracraft evaporative humidifier, (DH#803) that I've had for maybe 10 years. Last year I had problems with the fan blades not turning quickly when I turned it on. Then eventually they would get up to speed. This year the fan blades turned very slowly and then stopped, despite the motor running normally. Then the motor started to burn. Of course I turned it off. Is this a lubrication issue and is there a way to easily lubricate it? I have looked closely and it seems the plastic casing would need to be taken apart, not without some effort. There is no clear place to add lubrication. Is it worth it?
I have a aprilaire 550 that was not letting water through. I tapped the valve and it worked one time...
(More)
I have a aprilaire 550 that was not letting water through. I tapped the valve and it worked one time and now wont let water through again. Are there ohm checks I can do on the solenoid or is there a cleaning procedure for the valve?
