Question about Minolta Office Equipment & Supplies
I need belt for my minolta copier model AFR-7
I have to replace the belt for my minolta copier model AFR-7.
let me know if minolta has the parts. Or where can i order
  • 410 Answers
Part number #12ZL11450 is the part number for the AFR-10, AFR-12, AFR-13, I'm just not positive about the AFR-7.
Go to www.precisionroller.com and look at Konica/Minolta parts. You may have to email or call them on the phone to have them research the number.
About forty dollars plus shipping. Good luck
Posted on Oct 05, 2009
How to install Minolta dialta Di2510
Go to Konica Minolta Web site can use only windows 95 best is XP. If there is Windows 7 Go for it. This a legacy Minolta machine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 24, 2014 | Konica Minolta di-2510 AFR-19 AFR19 ADF...
P7 p28 p5 c300
For P-7 replace the magenta image unit
for P-5 and P-28 unless you know your way around Konica Minolta Copiers you need to have the two sensor located below the transfer belt on the right side cleaned and or replaced, to clean them you must uncover them because when the belt assy. is remove the are covered.
Mar 21, 2014 | Konica Minolta Bizhub C300 All-In-One...
Afr 19 jam
Where does it jam? as the document goes in or as it comes out. underneath the on the slit glass? Have the rollers all three been replaced? does the leading edge of the document have any dents in it?
Jan 24, 2013 | Konica Minolta di-2510 AFR-19 AFR19 ADF...
Code C0500 for Minolta Dialta model AFR-14 means?
mam/sir First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Jul 18, 2012 | Minolta Office Equipment & Supplies
mam/sir First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day BY the way the AFR number is for the document feeder not the copier
Minolta dialta AFR-14 hard drive
What model machine do you have the AFR-14 is the document feeder not the hard drive. Do you have Di251 or Di3510 something like that
Mar 24, 2012 | Minolta Office Equipment & Supplies
A MALFUNCTION WAS DETECTED - CODE C0500
Go to START MENU
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Dec 08, 2010 | Minolta Di3510 All-In-One Laser Printer
Hello, I work with Osceola County, FL Habitat
Sir the AFR-12 is the document feeder desiignation, the machine model number is located on the back of the machine or the right hand side of the machine (You saw the AFR-12 when you raised the document feeder correct?) As for copies being black the drum/cleaning blade mite need replacing. Remove the orginal glass the big sheet of glass and clean the optics use no liquids just a clean paper towel, there are about four minors two the right side plus clean the expose lamp (Bright lite that lites up) to copy the orginal be gentill. remove the black cover on the right hand side two mirrors under there The model mite be a EP2010, 2030, 2080, and or 3000?
Aug 22, 2009 | Office Equipment & Supplies
Can you help me
The AFR-9 is a document feeder part of a Minolta Di200/251/351/250/350 series of copiers. The model of the copier may be on the back of the copier itself. You can clean the glass with windex, the body can be clean with light soap and water, just make sure you do NOT clean any area around the Toner bottle section, Toner and Water will make a major mess. How many draws does it have? Does it have a finisher for stapling and hole punching?
Jul 15, 2009 | Minolta Office Equipment & Supplies
Minolta ep 1080 copier document feeder will not feed
What kind or adf do you have? Will it only do one sided copies (AFR-1) or can it do duplexing (AFR-9) ? If you have the one sided doc. feeder the sticky stuff you cleaned off is mostly the paper feed roller are mealting away.... Is the paper stoping right where the rollers are? If so you will need to replace the rollers and the shaft, there are one piece and one part number... It is a BEAR to replace the shaft, if you have never done it before. Also, that may be a hard part to find, it is a olld feeder. One other thing to look for is the paper stopping in the same spot & is it being shifted to one side like it is being blocked, you may have staple or paper clip or a post-it note stuck there. Good Luck
Nov 08, 2008 | Office Equipment & Supplies
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
