Question about Andis 01690 Hair Trimmer
1690 trimmer the turn handle to shift the clipper blade up and down is not working,how do i connect it back
  • 61 Answers
Possible broken pin inside the lever
Posted on Jan 26, 2009
  • 62 Answers
Please send your clipper to the Andis repair department at 1800 Renaissance Blvd Sturtevant, WI 53177. If this clipper is less than a year old repairs will be done at no charge with a copy of the receipt. If the clipper is more than a year old there is a $6.50 service fee and $5.00 shipping fee, there may or may not be a charge for parts depending on what actually needs to be replaced. If you would like to talk with a customer service rep please call 1-800-558-9441.
Thank you for purchasing Andis.
Posted on Jan 07, 2008
My husbands clippers won't cut
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
https://www.youtube.com/watch?v=DX4Xc47F_IE
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
www.fixya.com/.../t3222969-clippers_hum_like_working_but_dont_cut
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers · 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
www.rapidedge.com.au/cat/maintclip.html
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
Dec 21, 2015 | Health & Beauty
My clippers just stopped working...just gives a light buzz
oil your blade after each use. on the side there is a blade adjustment setting. after you oil the blade turn your clipper on, turn the set screw out a few turns till the blade is free. Then turn back in till it makes a loud clacking noise. Then u will back out the set screw till the baldes stop clacking and keep oiled well.
Mar 20, 2013 | Wahl Super Taper Hair Clipper 2000 Hair...
I have an Andis AGC 2 speed and I cannot figure out how to get the blade on and make it stay on when I turn on the clippers.
Ok you should be connecting the blade whilst the clipper is on this will ensure the blade engages with the clipper correctly, simply push the front edge of the blade into the clipper untill the latch has snapped into place.
Aug 19, 2011 | Andis AGC2 Hair Trimmer
Oster a5 clipper not cutting,blades are new,a5 is new,2 days old
make sure the blades are connecting to your clippers turn the clipper on and attatch the blade they should click into place and should not pull off untill the release latch is depressed.
Aug 08, 2010 | Oster 76076-010 Hair Trimmer
Can i sharpen my electic trimmers using sandpaper
Things You'll Need: Three-sided blade sharpener (coarse, medium, fine) Small flat head screwdriver step 1 Using the flat head screwdriver, unscrew the trimmer blades and remove them carefully. Wipe off any oil, grime or dirt that has built up on them as this may make it more difficult to handle and keep them in place during the manual portion of the sharpening process. Step 2 Separate the blades and re-apply only the moving blade to the tension spring. Then apply the moving blade to sharpener surface and turn the clippers or trimmers on. Hold the moving blade on the surface of the sharpener and apply light pressure while moving the blade back and forth for one to two minutes. You can also lay the blade on the sharpener first, then put the trimmer tension spring directly on the blade. Step 3 Turn off the clippers and remove the moving blade. It should look shiny and feel sharper. Step 4 Remove the guide from the guide blade by unscrewing it using the flat head screwdriver. Place the guide blade on the sharpening surface and manually run it back and forth for about one or two minutes or until it's been sharpened to your satisfaction. Screw the guide back onto the guide blade while being careful to readjust it before you tighten the screws. Step 5 Screw all the blades back on the trimmers and power them on to make sure they've been fitted correctly. Test them on your own hair to make sure they've been sharpened correctly and are set to the desired depth. Ads by Google Best Knife Sharpener Sharpen like the pros. Complete kit w/ 1x30 belt sander. Only $189.00 www.theedgemasters.com Braun® BodyGrooming Tools Try the Braun® bodycruZer? with Gillette® Fusion Razor Technology. www.Braun.com/BodyGrooming Oster ® Clipper Blades Oster ® Full Line Clipper Blades, Animal & Human Oster ® Blades. www.HouseholdAppliance.com STIHL Electric Trimmers Buy it. Plug it in. Trim it up. Depend on STIHL Electric Trimmers. www.STIHLdealers.com Tips & Warnings Which surface you choose, whether coarse, medium or fine, depends on how dull your blades are and how sharp you want to make them. If they are very dull, you will want to start with the coarse or medium side of the sharpener. If they just need a small amount of sharpening, use the fine side. If you've never sharpened electric trimmers before, you may want to visually observe and feel the sharpness of the blades with your fingers before you start to sharpen it. It may be hard to tell if the blades are sharp enough if you don't feel them just before you apply them to the sharpening surface.
May 02, 2010 | Andis T-Outliner Hair Trimmer
How do I adjust the blades or sharpen blades on a Andis T-Outliner trimmer? I have some older blades that work farely better then my newer blades that are dull if you ask me. Is there some way to manuver...
Clipper blade sharpeners are availale but the cost of these typically start at about $300 and go as high as several thousand dollars. This makes it unaffordable for home use.
For affordable, professional clipper blade sharpening, I suggest you contact the folks at clipperparts.com
Your clipper moves at just one speed. There is no way to 'speed it up' if it is working correctly.
Feb 05, 2010 | Andis 04710 Beard Trimmer
Andis trimmers are making loud noise when used outside US
First off all when buying a step down transformer for these clippers or any other electrical equitment make sure u read the label check cycle 50/60 ,and watt transformer need to be the same are close enough,with is hard to get on tha market,get it made custom,I'm a barber and we have a little trick open your andis clipper ,get spong cut it neatly just a bit thicker than the space between movin part and amateur (coil) insert spong between,not centre bit top bit to blade that's where knocking comin from it can cause that movin bit to break,trim spong until u get it quit but able to cut ,note blade will get hot because of wrong transformer and can damage coil
Nov 01, 2009 | Andis Styliner SLII Hair Trimmer
The trimmer does not move although charged!So the trimmer head can be slid onto the handle of the beard trimmer. Once it clips in, and I turn on the charge, the device works for at most a minute before...
It sounds like you may need to oil the blades with the clipper oil that is included with the kit when you bought it. The blades will become gummy and sticky after use. The "Wahl oil" provided with the clipper is specially designed to "de-gum" the blades and let them move freely. The knob you speak of only holds it from rotating and should have any affect on run time. The only other possibility is if the rechargable battery is at the end of its life which shouldn't be the problem unless it has been used a great deal.
Aug 12, 2009 | Wahl Vision 180 Beard Trimmer
Blade
Please call Andis customer service to discuss this problem at 1-800-558-9441.
Thank you,
Apr 10, 2008 | Andis 18140 Hair Trimmer
Hair Clippers not clipping
for Shorty8 adjust power screw,check connector fork,if too tight losen tension inside the clipper
Aug 28, 2007 | Andis 01690 Hair Trimmer
Andis 01690 Hair Trimmer Logo
101 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
