Question about Home
The handle keeps dropping off on my side mount. CST974CF. What do I need to get it repaired?
  • 334 Answers
You have several options here.
1) replace the handle with a higher quality all brass handle/nut/rod assembly
2) wrap the threads with teflon tape and then install the nut. (Yes, teflon tape is designed to prevent leaks, but it can tend to keep plastic nuts from working themselves loose.)
3) use a loctite thread locker product.
Do not use the red locktite, because you will never be able to remove it again.
Here is a link to a site for loctite425 thread locker designed for plastics. This is the blue medium strength loctite.
http://www.labsafety.com/search/Loctite/24551558/?type=brand
Posted on Oct 05, 2009
  • Shawn Johnson
    Shawn Johnson Mar 13, 2015
    Is the all-brass replacement you mention from Toto or parts you can find locally at a plumbing supply store?
How do I remove the door handle?
Brand and model would really help. Some handles have thin metal inserts that need carefully pried out with a small blade and then you will see the mounting screws inside the handle. Other handles have small allen head set screws in the side of each end of the handle that need loosened until the handle pulls off. Other handles have no screws showing but need pushed upward to release them from the mounting studs. Can't give the exact procedure without a model number.
Jul 12, 2015 | Refrigerators
The cold water handle assembly of my Kohler Stillness wall mount faucet keeps unscrewing from the valve body after a few days of use. I've hand-tightened it as the instructions say to but is there...
Automotive Thread-Lock compound will secure the parts during normal day to day use-and still allow the faucet to be disassembled for servicing. You will only need a drop or two, don't over do it.
Dec 31, 2010 | Kohler K-T945-4 Stillness Laminar...
How does the YB2808 holder detach from the wall? ......the above answer wasn't an answer....I need to know how to "unsnap" the thing....it IS NOT held on with typical allen screw, how does one...
The anchor is put into the wall in a pilot hole, a mounting post is inserted into the wall anchor, Afterwards the mounting post is pressed firmly until it clicks to stay in the mounting post with the handle down. The locking tab on the mounting post is faced down to fit into the specific area to stay put.
  • If this was over tightened it will be difficult to get off.
  • Try moving the handle from side to side, while pulling the unit off.
  • If all else fails, put tape around the handle, then slide a flat head screw driver under neath, and lift up. the anchor bolt will now want to come out but it can be cut off. Push it back in. Repair the hole and try again if you are moving it anyway.
Dec 10, 2010 | Moen YB2808 Eva Paper Holder - Chrome
I have a Jacuzzi whirlpool tub in my bathroom with a water rainbow spout and square handled valves. There is water leaking from the bottom of the valve body mount on the hot water side. Is this repairable?...
should have an o ring on packing nut..take off handle..under escutchion plate..should be a nut,,if you take some pliers and turn on you ll see were it needs tightening.
Nov 22, 2010 | Whirlpool Home
1994 olds cutlass has broken door handle.
replace the door best way to solve that problem
Sep 11, 2009 | 1994 Oldsmobile Cutlass Supreme
The top spray arm keep knocking
you could have a water deposit build op inside of the arm itself or the bushing that is in the arm at the mounting screw is worn causing the movement. Both are easy fixes. Remove the arm which should be mounted by a reverse threaded srew and check the balance by taking a pencil and marking the arm in the center (measure the arm and split the difference) place the arm on the pencil at the mark it should balance itself if not the side that dropped has calcium build up and can be cleaned by water hose and a little shaking. The bushinf should be a plastic coller that sits in the hole of the arm on the mounted side facing upwards. This bushing can be purchased at any appliance repair shop. Good Luck on your repairs
Dave
Aug 31, 2009 | Dishwashers
I believe foil was used in my micowave; it hasnt worked from that time. Can it be fixed?
Debi123,
Your oven can be fixed as most things can but it may be cheaper and better to replace your oven with a newer model; perhaps one that is able to handle metal objects. If you decide to fix your current oven then I suggest you remove it from its mount(if mounted) and drop it off at a reputable repair shop and save the costly service call. A repair of this nature will cost roughly $100 - $150.
Aug 29, 2009 | Danby Microwave Ovens
Kenmore 106.55526400 door handle needs mounting
Yes the door will need to be partially disassembled to reach the back of the screws. The handle is the lowest price I could find is at Sears Parts Direct CLICK HERE=> http://www.searspartsdirect.com/partsdirect/index.action?pop=flush
Get an account and enter model number.
To see the photo of the door click here below
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK0404023-00006.png
If you need more help please let me know. appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartseast.blogspot.com/
http://appliancepartsse.blogspot.com/
Trying to help but, Not sure you will be interested in the repair, Thanks, Sea Breeze
Aug 15, 2009 | Whirlpool ED2FHEXN Side by Side...
Once installed according to directions, i can't get it to work pr
There is two different types of handles. You have a front mount and a side mount. It sounds as though you might have bought one that is for a front mount instead. Also some toilets are brand specific and you are forced to buy OEM parts instead of generic ones. If the handle is metal you could try bending it to get the "swing" you need. But if you do that, you won't be able to take it back for a refund if it doesn't work. Good luck
Apr 02, 2009 | Danco 89448A Universal Toilet Tank Lever,...
Garmin Suction Cup (Rubber)
Put a drop of dishwashing detergent and a few drops of water on the rubber and distribute it evenly before You mount it to the windshield. This mixture enhances the suction power and keeps the rubber soft. Repeat after 3-4 months! If You don't like the look of it on the outside of the window, put a smiley sticker on it! :-)
Aug 09, 2008 | Garmin Suction Cup Mount with 12V Adapter...
Home Logo
165 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
