Question about Dell OptiPlex 170L PC Desktop
No post led lights 34 solid green - Dell OptiPlex 170L PC Desktop
  • 3,940 Answers
Memory subsystem error. Take out all RAM, try reinstalling modules one at a time. If system posts with one but not the other, that RAM module is likely bad. If no go, the motherboard is likely bad
Posted on Oct 08, 2009
Here's my problem, I have a belkin n300 extender, ok it worked for about a week or so and one day I lost connection, when I looked it is solid blue, even after I press reset or wps, it stays blue, I don't...
Blue?
the n300 colors.....
4 LED Descriptions
Router Link LED
This LED indicates the connection between the extender and the router or access point.
Solid green
. Best connection.
Solid ambe
r. Good connection.
Solid red
. Poor connection.
Off
. No connection.
Device Link LED
This LED indicates the connection between the extender and a computer or mobile device.
Solid green
. Best connection.
Solid amber
. Good connection.
Solid red
. Poor connection.
Off
. No connection.
Power LED
Solid amber
. The extender is booting.
Solid green
. The extender is powered on.
Off
. The extender is powered off.
WPS LED
Solid green
. WiFi security is enabled (WPA or WPA2).
Blinking green
. A WPS connection is being established.
Off
. WiFi security is not enabled.
Note:
If the Router Link LED or Device Link LED is amber or red, Find the Best Location
Mar 07, 2018 | Belkin Computers & Internet
Code 34 replaced lamp with 2 new osram lamps may run for 5 min or 5 hrs shuts down solid red light code 34
I have a Mitsubishi model WD-60737 and to make a long story short 1st time problem lamp replaced fine for a month til my uncle hooked a DVD player to my TV next day turned on with solid green light then TV kept turning off after 2 to 3 minutes of beingetting turned on and a solid red light to show after. What does that mean? It's a brand new lamp and worked for a month so why shut down now? Could my uncle have did something to where it shook up the circuits or something?
Sep 25, 2014 | Mitsubishi WD-60737 60 in. HDTV
The last led light blinks green and sometimes it turns solid red
red light is stands for hardware boot and the green one is stands for system boot and disc boot. when red light remains solid it means your system is in 0% cpu usage and nothing doing, stop working
May 09, 2010 | Intel SC5299BRP
My Dell 8200 Desktop just stopped working. It turns on but doesn't boot; nothing appears on the screen. I was told this is the motherboard. Does that sound right?
two things
  1. What does the power LED on the tower indicate? Solid Amber? Flashing Amber? Solid Green?
  2. On the back of the Tower are 4 diagnostic LEDs, what do they indicate? Normally they flash thru several sequences and stop ABCD all Green. If the stop in another pattern, post the pattern.
Feb 13, 2010 | Computers & Internet
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
Connect power swithc and led cables to foxconn n15235
Still have your Foxconn manual? Turn to page 19. See figure FP1.
Download manual from Foxconn, click on the link provided;
http://www.foxconnchannel.com/en-us/product/Motherboards/detail_overview.aspx?ID=en-gb0000154
System cases vary when it comes to wire colors. The most common wire colors for positive are, solid blue, light blue, solid red, solid green, light green. Negative wire colors. Each led, IDE-LED, Reset, PWR-LED and PWRBTN should share a negative colored wire. Common is the solid color white but this can vary from case to case.
Mike
Nov 10, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Power led solid red, internet led solid green
This is a sin of a bad unit already, first thin that you can try here is to reset the router by pressing the reset button of the device for 30 seconds , but after that and still the same light better contact your device manufacturer...
Sep 15, 2009 | Actiontec GT704WG Wireless Router...
Infocus X3, no light, LED is solid green.
the colorwheel. if it does not spin, the lamp will not light.
Aug 26, 2009 | InFocus Proxima UltraLight X350 Multimedia...
Diagnostic Indicator
Beep codes and power LED status are pre-post errors. Usually beep codes indicate a problem with a memory module. Power LED is solid green for normal operation. Solid or blinking Amber color power LED indicates a power distribution problem.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 13, 2008 | Dell Dimension 2400 PC Desktop
Dell OptiPlex 170L PC Desktop Logo
260 people viewed this question
Alun Cox
