Question about Panasonic CT-36HL43 36" TV
My dog ate my Panasonic TV cord plug off and I have a new plug but the Japanese wire color coding is totally different from US color coding so I don't know how to connect the wires.
ltfrc
  • 227 Answers
SOURCE: I need a power cord for an emerson tv
Hope the dog is well. Best to go to hardware store and buy a plug to replace yourself. Is it two wires, or three? Is it round or flat cable? Also if this is a continuos problem you might want to get a length of metal clad cable to put over the cord before you put the new plug on.
Mike
Posted on Mar 27, 2009
  • 9 Answers
SOURCE: just need to know which wire goes where
orange is normally illumination(not necessary) other is probably cell phone mute
Posted on Jun 12, 2009
  • 15 Answers
SOURCE: I have universal control remote philips but i
Try here.http://www.remotecodelist.com/remotes/
Posted on Jul 13, 2009
  • 73 Answers
SOURCE: i need a wiring diagram color code for a panasonic
look on this site:
http://www.the12volt.com/
Posted on Oct 31, 2009
chrisp2323
  • 36 Answers
SOURCE: hi i am trying to fit a panasonic model number
I have to say it, so let's get it out of the way; there are many professionals in your area who are capable of doing this for you. Whether it be Car Stuff or a Land Rover dealership, you can expect to have everything put just the way you want. But I have solved this problem myself once...
I have run into this problem on my Nissan Maxima. My solution was a bit extreme and involved quite a bit of butchery. You may decide to do something else. What I did was cut the connector off(to the original stereo) of the cart and spliced the power wires together. Then I turned on the unit and put in my favorite cd, adjusted balance to the front-left and touched wires together to figure out which was the proper speaker wire. Then did the same for front-right, rear-left, and rear-right. After figuring out the proper way to wire it in, I went back and installed ****-end connectors(wire nuts will work, but take up more space) and re-wrapped with electrical tape, making sure there were no wires or metal to ground out. If you do decide to cut the connector from the vehicle, leave enough wire on the connector so it can be reinstalled at a later date, 2-4 inches of room to work with(just in case you need to reinstall original stereo unit).
Think long and hard about if you decide to make this work. It is dangerous to modify a vehicles electrical system due to a RISK OF FIRE . Let me say it again--there are professional automotive audio people in your area who can do this. Check with Best-Buy.
Posted on Oct 12, 2010
My acer aspire one notebook won't boot up.
Is the new cord/charger/transformer the EXACT same power specs? When your "dog ate your charger", it may have shorted out something in the Laptop? Was it plugged it when your dog ate it?
Jan 16, 2013 | Acer Aspire One PC Notebook
Remote control codes for sabre tv
When are you people going to learn. The only way you will get it to work is to find the same remote that come with the tv, That is what happens when you buy unknown brand (Electronics) Not evan a good universal remote will work on them, Stick to a known brand.Like jvc,sony, toshiba,lg,panasonic. Then you won,t have that problem. If the dog ate your remote,Because you for got to (Feed) it.
Oct 21, 2012 | Sabre LCT371BKA LCD TV
Have a rule 1800 Pump and my dog ate the cord
so cut repair and tape and fix if its near water side use silicon make sure dosent hit water
Jul 22, 2012 | Rule 1800 H53SP-24 Swimming Pool Cover...
My dog ate the cord to the fan I need to know how to replace the old with a new one
Hi mlh9188
You can replace your cord that was eaten by your dog very easy.
Disassemble your fan.
Be sure to mark how the fan is assembled with an awl or sharp instrument to scratch an alignment scratch on the outside of the motor case before you disassemble it....maybe even take a picture
Once you have the fan disassembled to the point that you can get to where the wire that was chewed is connected to the fan, you will disconnect the wires from the plugs,sockets,etc...take another picture before disassembly.
Take the old cord with you down to your local hardware store,loews,homedepot,ace hardware,etc.
Tell the person in the electrical dept what happened, and he will fix you up with a new set up.
Come home install the new cord and plug...keep away from dog...
Please take time to rate me
Sep 10, 2011 | Patton U2-1487 Floor / Box Fan
I have an older model RCA television ( but it's ot all the hook ups for today) and my dog accidentally ate through the cord, should I take it to a shop or just buy a used tv somewhere else & not even...
I guess it depends how far up the cord your dog ate through it! You could cut the cord off at the bite, fit a new plug and use an extension cord to reach the socket. Other than that, I don't think its an expensive job to get a complete new cord fitted - depending on the repairer, it should still be cheaper than a replacement tv
Feb 04, 2011 | RCA Televison & Video
Mike
Mar 26, 2009 | Emerson EWF2704 TV
Cord to plug in
On a 120 volt plug, the smaller plug is black, power. The larger side is white, neutral. The center round plug is green, ground. Make sure your ac is not 220, the plugs are in line above the neutral. On 220 both are power.
Aug 05, 2008 | Goldstar M1003R Air Conditioner
Help! Dog Bit Through Electrical cord on Lakewood 2727. How to replace cord???
another option for you would be to use crimp on terminal connectors(**** connectors) you may purchase these from most hardware stores. Even using these I would still tape around the outside to ensure a good insulating surface.
Apr 28, 2008 | Lakewood 2727 Heater
How can I get a replacement charger and cord
you may go to your service center for this brand, and purchase a new one. you can also purchase from video cam centers with a different brand as long as the same specs, the same port, the same voltage requirement(input & output )
Dec 16, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Panasonic CT-36HL43 36" TV Logo
37 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
