Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
The sandisk is not work
Hi i had a sandisk and wen i tray to pu it music or others staff say is writer protection
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 05, 2009
L can not copy anything to SD card it says remove writer protection
Take your memory card out of the camera and switch the position of the "lock" tab. One position is for "locked" (i.e., "Write Protected") and the other position will allow the card to be written to (unlocked). Some cameras have image protection built into the on-camera software and you may need to configure this there.
Nov 08, 2013 | SanDisk 2GB microSD Memory Card
My computer keep on saying remove writer protection, how do l solve this?
There will be a sliding switch on the memory card, just move it to the other side and it should work fine.
My DVD Writer/CD Writer Combo got hung and I pulled out the tray
yes it is repairable but best way to get it repair is get it to some professional only
Nov 20, 2009 | Computers & Internet
Iam trying to download music on my sandisk micro card and it keep saying card is protected unprotect or use other disk
If you look at your micro sd card check for a switch that you can move. Move it in the opposite direction of that it is currently in. If this doesn't work try to change the switch on your sd adapter as well. If this still doesn't work switch the micro sd switch back to original state and try again. One of the cards has the lock activated. You just have to figure out witch one.
Please rate!
Cheers
Sep 28, 2009 | SanDisk 2GB microSD Memory Card
I want to know how to download music from itunes and other music sites to my sansa ipod.
iTunes music and video have DRM copyright protection, you can only play it on your computer or your iPod player. If you want to put them on other portable player such as Sansa, Zen, Zune, MP3/MP4 player, etc. You have to remove the DRM protection at first. I found a media converter can do that, it's easy to use and works pretty well for me, you may download it for a try.
http://www.youtubetoipod.biz/drm-remover.html
Sep 07, 2009 | SanDisk Sansa e250 MP3 Player
My sansa wnt work!
me 2 mine wont work either!!!!!!!!!!! wot the hel do we do!??
Aug 25, 2008 | SanDisk Sansa Clip MP3 Player
Writers protection
hi,
In Latop there is no option for "enable or desable write protect" only thing is you should have permission for writing a CD thats all.
please check do you have permission...
Regards,
Jishil
Jul 16, 2008 | Computers & Internet
Mp3 sansa e260
You will need to run those songs through an mp3 converter to get rid of the protected status, or purchase a premium subscription to your music service (the basic subscription will not be enough).
And, no this player is definitely NOT compatible with iTunes.The Sansa e200 enables users to play MP3, WAV, WMA, secure WMA, and audible files. iTunes are AAC format - not recognized by this player.
Jun 27, 2008 | SanDisk Sansa e260 MP3 Player
The sansa shaker
Reformat in Windows Media Player - it will erase all the songs so you can start from scratch.
Feb 11, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
75 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
