Question about LG WM0642H Front Load
Waher will not start
Washer originally would not spin and drain the water. An error messae of OE appeared. I drained the water from the front and cleaned the drain filter. The filter was not clogged.
Started the washer again and statred to work. My wife attempted to run the rinse spin cycle and it once again would not start. Now the waasher will not start at all, but the display shows the cycle as running and the timer also runs.
Any ideas?
  • 82 Answers
IF YOU DONT HAVE THE RIGHT TOOLS TO BREAK IT APART AND PUT IT BACK TOGETHER AND THE EXPERIENCE IS CHEPEAR FOR YOU TO CALL A TECHNICIAN OR BUY A NEW ONE!!!
TO FIX THIS PROBLEM IS A LITTLE TO HARD!!! NEEDS TO HAVE EXPERIENCE!!! SORRY!!
Posted on Oct 05, 2009
Assistance with rectifying as to why my LG top loader stops once it gets to the spin cycle. Can someone assist?
Before the washer can start to spin it needs to drain the water from the drum. By you having to drain the water from the machine indicates that the drain operation is not happening. This in the majority of the cases is a bad drain motor.
Aug 26, 2015 | LG Washing Machines
How do you fix Error Code OE on defy laundromaid electrologic 1300 ? Machine washes, but when it should start to spin, nothing happens - it's just making a noise for a while, no water releases and then...
If draining is not completed in a specified time limit the fault code OE will be displayed.
Check the drain hose is free (not kinked or deformed) and check there is no dirt in the drain filter.
The filter is located behind a cover on the kick-panel at the front of the machine.
May 01, 2014 | Washing Machines
Error message oe. and will not spin.
Actually, that is not oe, it is DE, which stands for Drain Error. Check the filter behind the access door on the lower left front of the washer. You should be able to drain the water out using the small hose there first before opening the filter. If there is nothing in the filter, you will have to replace the drain pump motor.
Feb 12, 2011 | LG WM1814CW Front Load Washer
"OE" error. Filter cleaned but makes terrible
You still have something caught in the drain line on the machine. Check the filter again and the lines coming from the tub to the pump, and from the pump to the waste line. Here is a link to LG's document on the "OE" error.
Jan 10, 2011 | LG WM2277H Front Load Washer
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
Front loader wm2277hs washer with OE error sign
The LG error code OE simply means “the pump is blocked”.
Presumably the water isn’t being emptied properly.
As with all error codes it is possible that there is a cause other than the exact description in the error code explanation.
And from your original post, I see that you have checked the drain pipe and the pump filter..
Those are the only 2 things I would of asked you to check aswell.
As for the price, I cannot answer that as most manufacturers wont publish their prices unfortunatly.
Sorry I couldnt of offered more help.
Mike
Jun 10, 2009 | LG Washing Machines
LG Intello wm-1460FHD stops spinning during the wash load.
OE is a drain error (indicating the machine has not drained out in under 10 minutes). If the drain pump is not coming on at all then you have a bad drain pump motor. If it is trying to drain then you may have a clogged up drain hose. The most likely cause is a bad drain pump motor. Hope this helps.
Jan 11, 2009 | LG WM-1480FHD Front Load Washer
LG WM0642H Front Load Logo
110 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
