Question about Hotpoint Aquarius WMA42 Front Load Washer
Initial set up WMA 30
I have this old washing machine delivered to me by the letting agency. They are so busy that it is lieing idle since a month. Hence I tried setting it up myself.Connected it to the colde and hot water pipes. cut of the blocked extension pipe at the sink trap and connected the drianage pipe to that.
Everything seemed fine and started it with some clothes.
To my surprise, the whole washing camber got filled with water and when the pressure increased, started overflowing through door, and not a single washing action started. I had to stop the washing machine, turn off hot and cold water supplies to drain out the water.There was still about 4 inches water left in the chamber which I had to drain using cup.
Can you please guide me, what might have gone wrong. The drain pipe connection to sink trap is at about 2 feet hieght(as is in the manual) and the washing machine on floor.
  • 139 Answers
Hey mike mate problem with the washing machine is minor, however your gonna have to get the top off the machine to get to it.
It seems to me that the plastic tubing connected to the pressure swtich has come away. OR is damaged leaking air. However it is common for it to come off in delivery especially when its an old machine and has no transit brackets.
Theres only two screws to undue, their near the front on either side of the machine.. located behind two oblong caps. remove caps remove screws and push the top back and off.. the swtich is directly behind the soap draw. it has two single wires and two wires on a plug attached.. DONT REMOVE THESE.
Check to see if a plastic tube is connected to it and running down to the filter compartment. most likey it aint hence causing it to overflow..
Posted on Dec 23, 2007
Wme8227s. What does code E18 indicate?
Beko Washing Machine ' WMA Series ' Error Codes
Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
Apr 27, 2014
Bosch WAS24460GB showing error F:57
Sep 28, 2013
beko washer error code
Aug 18, 2012
Samsung B1415J showing error code EA ...
Jan 9, 2012
More results from
Oct 30, 2015 | Beko Washing Machines
Hi, my Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer, won't rinse and I have to manually turn dial to spin, any ideas please?
Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 26, 2013 | Beko Washing Machines
I have been delivered a Aquiras Extra WMA 40 but I only have a cold pipe but I notice the machine has a hot and cold pipes do I connect to just the cold pipe and will the machine heat the water inside
No, the machine does not have a heater unless it has a sanitizing cycle which heats already hot water even hotter.
For the machine to work as advertised, you'll need hot and cold water connections. However, if you just hookup the cold water and run the machine on its cold-water setting it will wash -- the laundry may not be as clean as you would like in some cases, but the machine will operate properly.
Jan 06, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
No power
This is a lack of neutral feed to the door switch. The feed comes from the circuit board which is where the fault lies. However if fitting a new board i would advise replacing door switch as it was probably the initial cause.
Hope this helps & thanks for using Fixya.
Dec 16, 2008 | Washing Machines
I have a beko WMA 1715s washing machine, it will not work, the pre wash light is just flashing on and off, it will let you select a programme but when you press start it wont work, please can you help, i...
Either the child lock is on - press and hold quick-wash and anti-crease, at the same time for three seconds.
Or your machine need re-seting
Turn power button off (not at wall)
Select 90 degree wash
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
Apr 26, 2008 | Washing Machines
New WTW5700SW clothes washer. 1 week old. Worked great for 1 week. Temperature control problem. The cold setting provides hot water. The warm and hot setting provide cold water. The warm setting...
the temp thermister in the control panel is bad, lowes has a 30 day return policy if they delivered it have them bring you a new one, if you picked it up take it back, get a new one no need in starting out with an new almost out of the box washe with problems
Apr 13, 2008 | Washing Machines
Beko WMA 1715S
try unplugging and let it reset itself
Apr 03, 2008 | Washing Machines
Hotpoint Aquarius WMA42 Front Load Washer Logo
71 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
