Question about Dell Vostro 200 PC Desktop
Dell vostro 200 4 repeated beeps on start up
Dell vostro 200 4 repeated beeps on start up . won't boot up
  • 3,153 Answers
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes P
c
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Posted on Oct 05, 2009
Yes i just got through with a similiar problem and found out that it was caused by the internal battery, it beeped four times and then another 4 times caused the monitor to not come on and it would not boot up and start. after i took out the battery it worked fined.
Posted on Jul 07, 2012
Dell vostro 200 F8 menu won't respond to repair
to access the recovery partition you need to press Ctrl and F11 when you boot up which should start the factory recovery process.
Nov 11, 2012 | Computers & Internet
Why does my Dell Vostro 200 keep beeping?
Defective memory can cause blue screens, no video, beeping sounds. It's possible that you have a defective memory stick.
May 24, 2012 | Dell Vostro 200 PC Desktop
I purchased 2 GB chips to try to increase the speed of my desktop. After putting in the chips my computer won't boot back up, my monitor is black and the computer is making a constant beeping nois
OK. First, I'm assuming that you have a Dell Vostro 200 as per the topic title. That said, you machine has a maximum memory capacity of 4GB. So, if you added the 2 - 2GB DIMMS in slots 3 and 4, leaving your original memory in the machine, you will have problems. You must be using DDR2 667 or 800 MHz RAM and the two DIMMS must be in slots DIMM1 and DIMM2 ( closest to the processor). No more than that can be installed.
Apr 03, 2012 | Dell Vostro 200 PC Desktop
Vostro 200 four beeps at startup then repeats; fan stays on.
Cant say for sure what the problem is, but most probably it is due to a bad RAM module. Try removing it and after removing the dust on the RAM and its slot Re-insert it. Also try cleaning up other areas with a blower too. It should workout.
May 28, 2010 | Dell Vostro 200 PC Desktop
Dell Vostro 200, freezes, then won't boot
that's a lot of info to work with - start by taking the cover of and blowing the dust out of it.
May 16, 2010 | Dell Vostro 200 PC Desktop
Dell vostro 200 4 beeps then with f2 starts
here is the explanation of what can be possibly wrong,
1 long, 2 short - Video adapter error: Bad or improperly seated video card
Repeating beeps Memory error: Bad or improperly seated RAM
1 long, 3 short-Bad video RAM or video card not present
4 short Keyboard communication failure: Bad keyboard controller or keyboard
This is what the typical explanation is. To avoid assumption, i will need info on *********** board...thanks,
Mar 19, 2010 | Dell Vostro 200 Mini Tower With 20" Flat...
How do I get my Vostro to boot from disk instead of HD It has been password protected and I do not have the password.
Turn on your compter and repeatedly press F2 (or F12) to enter the BIOS set-up. When you get to the BIOS, change the order of the start-up to read from your disk first.
Mar 03, 2010 | Dell Vostro 200 PC Desktop
Won't boot..getting 2 short beep codes..have tried memory that i know is good.
Its the problem with the memory only. the memory u get from dell will noit suite ur pc. try changing the same type and speed memory
Apr 20, 2009 | Dell Vostro 200 PC Desktop
Dell Vostro 200 PC Desktop Logo
5,882 people viewed this question
Alun Cox
