Question about HP Pavilion F1703 17" LCD Monitor
When I turn on my monitor it comes off after 2 seconds, like if it were going to stand by mode, do not know how to keep it running
  • 3 Answers
I had same problem chech the monitor first sounds like mine replaced it and its good now
Posted on Oct 27, 2009
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
LG W61 monitor keeps going 2 power save mode & won't come back up
trromig, I really don't think it's in powersave mode. I think that your CCFLamps are turning OFF because the Switch-mode-power-supply/Inverter supply is going into SHUTDOWN MODE after detecting a FAULT condition. First thing to do is visit YOUTUBE and search out long 8-12min video clips of LCD monitor disassembly and or LCD repair. If you are now using your pc with a swapped in monitor to do this FIXYA type thing, then you know it's not the PC that could be the problem! It's the LCD! One thing you failed to mention was the AGE and approximate total "ON" hours your Lucky Goldstar W61 has on it. It helps to know that information in diagnosing the cause of failure. Is the unit still covered by warranty? We here at fixya need to know these things to give you advice on all the options you have. Get back to me on fixya or e mail lmistyrel @ aol.com Bye for now. I'm louie12fix on fixya
Oct 07, 2009 | LG Computers & Internet
My 906 bw shuts off after 2 seconds, if i turn
Actually, this problem can be fix going to power management under control panel. You have to log in in safe mode in order change configuration. It displays stand by monitor and you choose the time that you see fit.
Aug 30, 2009 | Samsung 906BW LCD Monitor
LCD monitor shuts down every after 2-3 seconds
dustcore025, Need a little more info here. Do you know age of monitor? Was it or did it display a "perfect' image on it the day before? Is it under warranty? How far are you willing to go to try and repair this thing? Do you know how to "part" the snap together plastic back cover from the bezel, after removing the pedestal? This sounds to me like a Switch-mode-power-supply or Inverter problem that occurs when some Electrolytic Filter Capacitors get a little bit TIRED of being constantly subjected to high temperatures near heatsinks that are used to keep semiconductors within operating limits. You can determine how bad this may be if you can do a test and remember what happens. Here is what to do. Make sure PC is fully booted displaying WIN desktop or some other screen. Next, with someone to keep hitting the CTRL or SP bar key every 20-40 seconds while you reconnect both cables of your MM17 back to the PC video port and ac outlet. Now try to turn on the monitor and note exactly what you see and for how long. Did it have a sharp clear image, even for 1-2 seconds? did the screen go black? OK! Next thing is to shine a bright flashlight onto the screen 2 inches away from where you know there was something a few seconds ago. Try it at different angles and not if you see anything. get back to me with results of test. I'm louie12fix on fixya or lmistyrel @ aol.com BYE for now.
Apr 05, 2009 | ASUS MM17T (Silver) 17 inch LCD Monitor
Acer AL1916W pluged into lap top but can't get both to run.
Have you used the Fn button on your laptop and changed the video display Icon on the Blue Function keys. You need to change the display wait a few seconds for it to take affect. There are several modes try them all so you know how to use them.
Mar 20, 2009 | Acer AL1916W 19" LCD Monitor
MY DELL SE198WFP GOES TO POWER SAVE MODE AFTER 2 SECONDS
I had this problem as well as a lot of other people. The solution is to go to the power options in the control panel and turn power saver off. This should keep the monitor from going into power saving mode.
Dec 29, 2008 | Dell SE198WFP LCD Monitor
Monitor keeps going i to sleep mode
Check the cable it's not connected correctly or check you CPU is it working fine.
Dec 08, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Moniter turns on for 2 seconds turns off
hi guys, first run the system in safe mode, and with vga mode, see if it is the same problem ?? let me know
Dec 30, 2007 | Acer AL1916W 19" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
67 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
