Question about Nikon COOLPIX L18 Digital Camera
I CAN'T CHANGE TO VIDEO MODE FROM CAMERA - Nikon COOLPIX L18 Digital Camera
Picturess are too green
there are advanced color correction modes,
Blue or dark pictures/videos
Keep your shooting distance inside of 2ft to 3ft, depending on
visibility and ambient light.
If you are using only one light, considering adding another light
(dual lights) or/and external flash accessory. The ideal
set-up is a combination of a light plus flash.
Consider purchasing the SeaLife Wide Angle Lens (SL975). The
fisheye lens allows you to get closer to the subject and fit more
into to picture frame.
For SeaLife camera with external light accessory (No external flash):
1) Set the camera's scene mode to Sea mode or Snorkel mode
2) Change camera's PHOTO and VIDEO White Balance
settings to DAYLIGHT.
For SeaLife camera with external light and flash accessories:
1) Set the scene mode to Ext. Flash mode
2) Change the VIDEO White Balance setting to DAYLIGHT.
For other underwater camera brands:
1) Set the Scene mode to "Auto" or "Underwater" scene
mode, as recommended by the camera manufacturer.
2) You may also need to change the White Balance setting to
DAYLIGHT depending on the camera's underwater color
correction or if pictures/video turns out red.
Mar 05, 2014 | SeaLife DC1200 Digital Camera
Video/movie mode stuck
Have you tried to reset the camera?
Reset switch is on battery compartment you will need a small needle or toothpick. Let me know if this works!
Jan 02, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
How do i get phone to change from video mode to photo mode?
Nigel,
After you start the camera, please go into Options and select the Icon for a still camera. The phone will switch over to the still camera mode. Again, to switch back to the video mode, select the icon of a video camera.
All the best.
Apr 03, 2011 | Nokia 5800 XpressMusic Smartphone
Vivitar 5018 cant take videos i want to take
first hit the home button and you will be able to change modes and stuff navigate just like the menu and there is a video mode picture mode and place where you can see all your stuff there is no external button or swith or anything though so it is kinda annoying but the quality is pretty good
flex10
Feb 21, 2010 | Vivitar ViviCam 8025 Digital Camera
How do u change from video mode to camera mode
Select the settings of the camera and simply change the mode from video to camera. ;)
Nov 06, 2009 | LG KU990 Viewty
Canon HV10 camcorder - can't get video mode to playback
hi, if you get blue screen,but your recording has been ok, then you must be change LCD FLAP, you sure get fix your camera,
Aug 30, 2009 | Canon HV10 HDV Digital Camcorder
My camera is not taking photos but just doing videos automatically i cant change it to photo instead of video
look at your phone. on the right side, there is a slide button. slide it to camera mode. now press the camera button you can change to video,photo viewer, or camera mode with the slide button.
hope it helped!
Apr 19, 2009 | LG KU990 Viewty
Does not chnage back from from Photo mode to Video Mode
If you have been using this camera for a long time, most likely the function switch ( the one you turn to change from photo to video mode) contacts are worn out. you have to take this one to a repair shop to change the function switch.
Regards,
Luwangula
Oct 30, 2008 | Panasonic NV-GS180EF-S Mini DV Digital...
Setting the tape speed
Power up camera on Camera mode, go to menu, select camera settings, go to Record Mode and select SP or LP there. Now your camera is ready to record as per selection.
You can not change speed SP/LP during playback mode because its properties of signal set during recording.
Mar 15, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Noise during video recording
Turn off Continuous AF (auto focus) to prevent recording camera noise during video capture. When you turn off Continuous AF, you may notice a narrower area of focus or depth of field, especially if you zoomed to a telephoto position before recording. Turn the Mode dial to Video, then press the Menu button. Highlight the Continuous AF menu, then press the OK button. Highlight Off, then press the OK button. (On is the default.) Press the Menu button to turn off the menu screen. This setting remains until you change it, change the Mode dial, or turn off the camera.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
35 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
