Hello! I am still in search of an answer to my Panasonic Plasma TH-46PZ80U. The picture is virtually non existant. The sound is ok, but the Picture is a Red to purplish haze, you can see a hint of the picture in the background. This started awhile back, and was intermittant until yesterday and it just stayed red to purple. I was lead to believe that it something to do with convergence, I dont know if this is correct, if it is , Where are the IC'c located, as I have the back off of my TV right now. Thanks
  • inspectionga Oct 05, 2009
    hello! Thanks for your quick response, in reference to the heat sink problem you mentioned on my Panasonic TH-PZ4680U, is there a particular board to check first and do I need to remove the board to see the loose/cold solder joint at the pins
    Thanks alot, sounds like I might need you to come to the house. ha ha Been to Arkansas lately? Thanks a million
    Derek
  • 19,396 Answers
Plasma TVs do not have convergence ICS or convergence circuits.
If you did not know this , you should not attempt repairing the TV.
If picture is very dim and faint, that is usually caused by bad sustain boards, sometimes a faulty plasma panel or a different problem related to high voltage circuits.
Sustain boards are located at two sides of the plasma panel, and their function is to keep the high voltage on plasma panel. They are familiarly called Ysus, Xsus and Zsus, depending on their location and on the model.
In your model the boards are Y sus and Xsus. Parts are expensive and must be tested before replacement. Test is done measuring impedance on boards resistors, reading voltages etc.
Here the parts:
YSUS SC BOARD TNPA4410 AB from PANASONIC TH-46PZ80U
XSUS SS BOARD TNPA4411AB from PANASONIC TH-46PZ80U
Regards
Posted on Oct 05, 2009
  • 6,927 Answers
Sounds more like a heat sink has a cold solder,look on back of circuit board,for a burned out solder joint on a heat sink,You can repair this your self ,with solder and a solder iron.The factorys some times don`t solder all the componets in properley with the robotic irons.So check it out,it will be a burned out place with the heat sink legs showing threw.I hope this helps you.
Panasonic TC-L47DT50 no picture no sound front lights com on
No picture or sound in my Panasonic TH-P42UT30A plasma ...
https://www.ifixit.com/.../No+picture+or+sound+in+my+Panasonic+...
iFixitAug 1, 2014 - Hi Ifixit,. I've got a Panasonic th-p42ut30a plasma tv that has a fault with it. The standby light is on (red) but it doesn't come out of standby.Missing: l47dt50
Panasonic Product Support - TC-L47DT50
shop.panasonic.com > Get Support
PanasonicSMART VIERA® 47" Class DT50 Series Full HD 3D LED HDTV (46.9" Diag.) ... Issues Addressed: Solves issue where the Emergency Alert System is displayed on the TVhours after the termination of the message. Solves issue where the Emergency Alert System is displayed on the TV hours after ...
Panasonic TX-P42X50B No Picture Or Sound ' Dead ...
? 9:00
https://www.youtube.com/watch?v=EanHoWLLpxU
Nov 6, 2014 - Uploaded by Electronic Workshop
Panasonic TX-P42X50B No Picture Or Sound This plasma television ... TV repair, clicking and will not power on, loud snap,no picture, etc.
Jan 27, 2016 | Panasonic Televison & Video
My Panasonic plasma Tv does not have sound. How do I fixed that
Sound no picture on 50 inch samsung plasma ps51d450a2m - HDTV ...
www.tomsguide.com/.../58009-4-sound-picture-inch-samsung-plasma-ps...
Jul 1, 2015 - 4 posts - ‎3 authors
There is sound and no picture on plasma tv, remote works at times but ... My pioneer elilte has this mode, and it is pretty easy to completely turn ... When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
Problems with blu ray player and plasma tv - HDTV ...
Nov 16, 2014
I do not have audio out on my tv how do i connect so ...
Dec 18, 2013
All channels on my tv have sound except channel 3 ...
Jun 29, 2010
More results from www.tomsguide.com
Dec 07, 2015 | Panasonic Viera Th-50px60u 50" Plasma...
PANASONIC TV MODEL # TH-46PZ80U BLINKS 10 TIMES
had the same problem with my panasonic, it was a faulty power switch, its a common fault with them
Dec 31, 2013 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic plasma tv turns on but no picture or sound
Same issue with - Panasonic TH-50PX70A , power UP with red standby, then power ON by remote - only Gives GREEN led blinking 35-40 times, followed by solid green led with no no picture no sound.
>> Solution; unplug Plasma from AC 10-15min, then plug in & power on to Red standby led,, At this point - Power ON tv while holding down both -Volume Down and F (function Select) buttons (front panel door) at the same time turns picture ON,all ok.
Jul 25, 2011 | Panasonic Viera TH-50PX80U Plasma TV
My Panasonic TH-42PX75U 42 in. Plasma Television has a problem: No picture Sound OK
this looks like a defective sc board with or without buffers repaire cost about 400 dollars
May 31, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
No picture sound ok,osd ok.
LG 42pj350r this led tv sound ok but not cume picture
May 25, 2010 | Panasonic VIERA TH-42PX80B 42 in. Plasma...
Panasonic Viera 46" plasma~no sound, no picture
I would use the warranty at Bestbuy at that point. Opening up the TV would most likely void the warranty.
Jun 28, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
