Question about HP PhotoSmart 7960 InkJet Printer
How do i load 5x7 paper? - HP PhotoSmart 7960 InkJet Printer
  • HP Master
  • 8,404 Answers
Same as 8 1/2 X 11 ... slide the paper guide in to the appropriate setting for the paper you are using.
Posted on Oct 05, 2009
Mg5620 canon How do I load deskjet printer with 4x6 or 5x7 photo paper there no slide
When you lower the front door for the paper tray, you should pull outward on the door to extend it to the stops. This should reveal a guide. Here is a link to the online manual. There is a written and visual description of paper loading starting on page 146.
http://gdlp01.c-wss.com/gds/9/0300015759/01/MG5600ser_OnlineManual_Win_EN_V01.pdf
Mar 24, 2015 | Canon Office Equipment & Supplies
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
How do i get my printer to grab the paper that is about the size a little bigger than a 5x7 and not make it go crooked?
Make sure you have all of you feed paper out. Look on the right hand side of the feed load slot for a diagram that will show you which way to put it in. It is etched or indented now and you will not see any different color.
Jan 08, 2011 | Epson Stylus CX4200 All-In-One InkJet...
Printing 5x7 card stock in HP 1510 injet all-in-one printer
You need to set up your printer preferences to accommodate the type and size of paper you wish to use, usually listed under printer/print or page set up.
Invariably, paper is loaded, butted to either left or right of the paper feed, but on the other side of the feed there should be a sliding stop which keeps your paper in place.
If feeding from the top feed, print side towards you, if printing from a tray at the bottom of the printer, print face down.
You can download a user manual from here once you've chosen your model printer:-
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R135-1&h_query=+HP+PSC+1510&submit.x=11&submit.y=7
Apr 22, 2010 | HP PSC 1510 All-In-One InkJet Printer
Have hp photosmart printer 7700 series problem loading 5x7 photo paper into printer
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr5
Aug 18, 2009 | HP Officejet 5610 All-In-One InkJet...
Cannot print 5x7 photo with i550 printer. What do
The i550 is capable of printing 5x7, the print software you are using may not be capable. The paper is loaded in the feeder lengthwise all the way to the right. If you are getting error codes, that's a different story.
Aug 13, 2009 | Office Equipment & Supplies
When I tryto print 5x7 prints from windows fax viewer my photosmart all in one model C4480 is printing the first 5x7 fine but the second 5x7 also has a small wallet size printed ontop of it
Solution one: Print on heavier paper Try printing on a thicker type of paper. Solution two: Check driver settings If printing on plain paper, make sure the driver settings are set to Plain Paper.
  1. To change the driver settings, click the Properties button in the Print window.
  2. If the Paper Type is not set to Plain paper, click the drop down box and choose More .
  3. Find and click Plain paper , then click OK .
  4. Click OK to return to the Print window and click OK to continue printing.
Jun 18, 2009 | HP Photosmart C4480 All-In-One InkJet...
How to load 5x7 photo paper into hp photosmart D7460 ??
Simply set the page layout option to select from printer. Place the cut & proper sized paper in the inlet tray, adjust the sliders so that they just rest lightly against the edge of the paper. Remember only one slider moves and the other one remains fixed to one edge. Click print preview. You might get a message saying paper orientation is not right...should I adjust the printer automatically, click yes and behold it will print in Portrait or landscape mode depending on the matter. If it warns that output does not fit on the media(paper) then select fit to page option.....sodeep
Mar 22, 2009 | HP Officejet 5610 All-In-One InkJet...
Adjusting paper size guides
Adjust paper guider, if not see media size support or not ....
Mar 15, 2008 | Samsung Laser Multifunction Printer Toner...
Print 5x7 invitations on my 950?
Change the size of the document on word to a standard sized document - such as 8-1/2 x 11. Then when you go to print the documents, set the printing preferences to print on 5x7 paper. That should do the trick.
Oct 04, 2007 | HP PSC 950 All-In-One InkJet Printer
HP PhotoSmart 7960 InkJet Printer Logo
239 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
