Question about Porter Cable Cable 12800 Riptide Saw Blade: 7-1/4", 18-Tooth, RightTilt, Thin Kerf
Cable is plugged in but picture is fuzzy, what do I do?
  • 8,404 Answers
You have a rip saw that has a cable with a fuzzy picture?
If this is a cable TV question, two things come to mind ... TV is out of adjustment or you have some ground wires touching your center conductor on your RG-59 or RG-6 cable (or just came to mind - you have split the signal so many times there is no signal).
You can use a cable tester to test the quality of the cable ... you can cut off the ends and replace them. More likely than not, unless you have pro tools and ends (F fittings) you will not get much improvement from this. If you are guilty of multiple splitters in the line, reduce the number of splitters.
If this is a saw question, I dont understand your trouble.
Posted on Oct 05, 2009
Fuzzy picture
Try moving the hdmi cable around, disconnect it and reconnect it. Try using a different video source.
Oct 20, 2012 | Hannspree Televison & Video
Audio problems - great picture -fuzzy sound
yes..that would make sense..the cable is getting dried out, and has less conductivity when it's hot or warm..that's not unusual
Feb 29, 2008 | Sony KP-57WV600 57" Rear Projection...
Picture went completely fuzzy. What could the problem be?
The tv CRT( picture tube) have a radiaton posion infected in ur tv picture tube.This is how u discharge the CRT(picture tube) get the posion out.Take the tv back cover off.Take video board that connected to the CRT(picture tube) out.Plug it in,so u have a live current to the CRT(picture tube).Find a wire like an AV cable,should be find.One side of the metal,grounded to the metal frame somewhere.Take a long needle plier grab the other side of the AV cable wire,not the metal,(Caution high voltage live current).Come very close to the open CRT(picture tube).U will have a live current arc,than u,will hear a big "POP".U,just discharge the CRT(picture tube).The tv now the CRT(picture tube),now it good,it clear of posion infected in ur tv picture tube.Now,unplug ur tv.Put ur tv,back together.Hook up ur tv signal cable and plug in ur tv,now ur tv picture,will be clear,completely.I do this many times to dicharge fuzzy CRT(picture tube).When i was a tv Tech.for the SONY TV Corporation.
Oct 12, 2010 | Sanyo HT32546 TV
Cable picture is fuzzy
Call your cable company as there might be a problem with the drop line or aerial coming into your house. now another thing is if you have a signal splitter( ex: 2-way, 3-way, 4-way) before the cable box, that could be degrading the signal as each input may drop the signal significantly. remeber, don't use too many splitters as they will make the signal faded/fuzzy. also, make sure all the connectors are clean and are not badly bent or the ends frayed. If you can see wire insulation from the cable line then it's no good.
Apr 05, 2010 | Insignia 42" LCD Flat-Panel HDTV
New flat screen hdtv has a fuzzy picture
Yes you will get a better picture quality out of a cable box if you get an HD cable box.
The reason you are getting the diminished picture is due to the signal you are feeding the TV is an analog signal. The newer HD TV's are made for digital TV and this older technology shows all its flaws on this type of TV.
When you get the new box understand that the same channels you are getting plugged directly into the tv are still going to have some grainy look to them but the good thing is that a lot of them are starting to be rebroadcast on HD channels and that is where your new toy will truly shine.
Enjoy your new TV...
Good Luck...
Jan 05, 2010 | Philips 23PF5320 23 in. HD-Ready LCD...
Fuzzy picture on PS3.
my ps3 just switched from a component tv to hdmi but the screen is fuzzy and off color and i've tried reseting the system but it's not working. help?
Dec 30, 2009 | Sony Playstation 3 (PS3) Console
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Fuzzy pictue
I sugest replaced the tuner or take the tuner apart and look for cold solder connections and insufficient solder connections.Good luck!
Jun 14, 2008 | Zenith C27A24T 27" TV
Fuzzy picture
1.check cam is jammed
2.check whether the drivers are installed properly
3.check the USB adapter cable
4.Remove cam .plug and install proper driver.
5.Check Video settings to default values
6. Else camera-video signal processing circuit might be damaged
thank you !
Nov 30, 2007 | Microsoft LifeCam NX-6000 Webcam
52D82U Fuzzy picture
Change your input source. You are probably on Input Source "TV". My HDMI cable is plugged in INPUT 4 so make sure that your TV is set to the right INPUT.
Oct 07, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Porter Cable Cable 12800 Riptide Saw Blade: 7-1/4", 18-Tooth, RightTilt, Thin Kerf Logo
63 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
