Question about LG DLE5977 Stainless Steel Electric Dryer
Crack in drum at seam
We bought an lg blue front loader dryer two years ago, we started hearing a rumble noise like shoes in the dryer. Over a few months it started getting louder and louder...I didn't think it sounded right because it used to be pretty quite during operation. Anyway I started to look at the drum inside and noticed a defect in the welded seam towards the rear it's comming apart. If you turn the drum by hand very slow you will get the rumble sound when that tear in the seam is on bottom. Please help, this is a defect i would think.
Thanks,
Roy
  • gonzo3333 Mar 09, 2010
    It has a 5 year warranty and i have a copy stating that from home depo, if you need it shoot me an email address. Their customer service sucks!!!!!!!!!!!! They had to honor the warranty and they fixed it.
    It cost me $85 for the service call and labor, it's back to normal now.
  • yadayada
    yadayada May 11, 2010
    suggest you try the Live Chat option of this site.
We had the exact same problem with our LG dryer but the crack was in the front near the door. The service tech as well as the engineer from the LG R&D department both agree that it is a manufacturing defect...the result of a poor welding job by LG. The service tech replaced the dryer tub today and the dryer is as quiet as when we first bought it. I paid for the part and the repair myself to get it fixed quickly. The service tech said to use it with the crack could be a fire hazard since the heating element is open under the tub. However, the service company we use will reimburse me for the cost of the part if LG agrees to reimburse them. I am in the process of working with the resolution department to get them to agree to pay for this part. It is no longer under warranty but since there engineer has agreed that it is a manufacturer defect, I am hopeful I will get my money back!
Posted on Mar 08, 2010
  • Steven Strack
    Steven Strack Jan 11, 2014
    I don\'t have a solution but it appears that dryer tubs of various makes are having the same problem. I have a SAMSUNG DV410AER/XAA 3 1/2 years old and started hearing a thumping noise a couple weeks ago. Took a close look today and found a crack in the dryer seam near the front. Did a Internet search and there appears to be a lot of these drums cracking. Why can\'t these tubs be made a little better. There should be a recall or zero cost replacement for these. I called SAMSUNG customer support and didn\'t get any support. This is a major cost to replace, granted I can replace myself but do I really want to take the time to replace only to have another one crack? What is the consumer to do, and pay to have it fixed will cost about half what a new one will cost. Don\'t know what I\'m going to do because I thought about buying another brand but it appears that LG, SAMSUNG and I don\'t know what ever other brands can\'t be bought in confidence.
I have a stackable washer/dryer gas maytag. Purchased around 17 years ago. The dryer is not drying clothes. Gas is powered fine and it is heating up. The cycle seems shorter than normal
The problem with it not drying is most likely going to be a worn out blower wheel thats slipping and not moving the warm air through the clothes to dry them properly. Always a pretty good sign the blower is slipping is,if you hear a rumble noise from the dryer at start up and also that same rumbling noise when the power stops. So if you hear it at start up...wait 30 seconds and open the door and listen for the rumble noise as drum stops. also you can check where the vent exits the house and see if their is air flow when the dryer is running.
GENE
Aug 19, 2011 | Maytag LSE7806A Top Load Stacked...
Very loud noise like tennis shoes drying
Check for a possible cracked weld in the seam of the stainless steel drum. Noise most likely is the crack passing over the front or rear rollers each revolution.
Mar 24, 2011 | LG DLE2515S Gas Dryer
With my dryer which still dries well. I get a load thumping noise on its rotation even with no items in the dryer. What would be the fix for that
Look at the inside of the drum, at the seam. At the front or rear side you will probably find a crack in the stainless steel weld. The fix is to replace the drum.
Jun 15, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG DLE2514w electric dryer has loud thud every turn
Most model dryers are supported at thge rear of the drum with a bearing configuration, but usually the front of the drum is supported by some lining pads or guides. These help hold the rotation of the drum concentric. It sounds like your drum is not spinning concentric. My guess would be that some new guides might need to be installed.
Hope this helps...
Sep 02, 2009 | LG DLE2514 Electric Dryer
I have a thumping noise as the dryer runs, but it seems to work fine.
Look closely at the seam of the dryer drum, at the very front and the very back. I suspect that the seam has developed a crack, and makes a thumping noise each time the crack passes over the drum support rollers. You will have to replace the drum to eliminate the problem
Jun 28, 2009 | LG DLE5977 Electric Dryer
LG DLE7177WM began making loud RuMbLiNg sound.
I have the same problem; pulled it apart and discovered the drum was cracked at the seam where it was welded. the noise occurs as it passes over the wheels the drum rests on. called LG's Cusomer Diservice and nobody was interested. found the same problems by others while searching myself so its clearly a manufacturing problem.
Jan 24, 2009 | LG DLE7177 Dryer
Bumping noise
Just had the same provlem and the drum is in the back of my truck. Open the door and manually turn the drum slowly until you hear the thump. Look at the seam that runs along the baffle and pay attention the seam near the raer and see if it separates when you hear the noise. A common problem is the weld breaks and you will need to replace the drum or take it out to have re-welded unless it is still under the year warrant which I am guessing it is not. Don't even try to call LG because they will not help in any fahion.
Dec 29, 2008 | LG DLE2512W Electric Dryer
There is a knocking noise when drying clothes
Look for a crack at the welded seam of the dryer drum. Noise maybe coming from the crack when it passes over the drum support rollers. Check front and back side of the seam. Solution is to replace the drum. If this is not found, please describe your symptoms in more detail.
Dec 23, 2008 | LG DLE0442 Electric Dryer
Banging noise
You may have had a foreign object slip under a loose drum baffle. Manually rotate the drum to locate wwhich baffle it is in.
Apr 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Rumbling noise
Most likely the rear bearing is bad. It would most likely not be cost effective to repair.
Dec 01, 2007 | Frigidaire FTF530FS Front Load Washer
LG DLE5977 Stainless Steel Electric Dryer Logo
179 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
