Question about Compaq Keyboard
I HAVE A COMPAQ KEYBOARD. I DID SOMETHING STUPID. I CLEANED MY KEYBOARD WITHOUT TURNING OFF COMPUTER. NOW THAT IT IS ALL CLEAN MY SPACE BAR BUTTON AND THE AUX. BACKSPACE BUTTON(RIGHT NEXT TO IT) ARE SWITCHED. WHEN I WANT TO SPACE I BACKSPACE. IT IS TERRIBLE. HOW CAN I REVERSE THIS PROBLEM? THANK YOU RON DRENDEL
    President:
  • 2,600 Answers
Try getting the cans of compressed air you would get at an office supply store, power down the laptop and trydrying the board with short bursts of air, there may be some dampness under the keys interfereing with the imput signals from the key pads.
Posted on Oct 05, 2009
W2241t problem, goes into standby mode and wont come out
press space bar or enter button. and wiggle your mouse. should wake up the monitor
May 04, 2013 | LG Flatron Computers & Internet
My dog knocked over my Compaq keyboard. Now the divided spacebar is opposite what it should be. Instead of spacing on the right spacebar I have to hit the left side. How do I fix this?
Pull the space bar off by using your fingers. Underneath, you'll find a metal rod. Take note on which way it is facing, and how it fits. Make sure nothing in broken under the space bar, then put the space bar back on making sure it hooks in correctly.
Mar 08, 2011 | Compaq Keyboard
Have a HP Pavillion 3163cl Entertainment Laptop and the Space Bar asks like someone is pressing down on it at all times. Like a stuck key and makes the noise when turning it on. The Laptop belongs to my...
To clean your laptop's keyboard you have to look under your laptop, you can see like keyboard icons with some scews, so, open them, they will let yout to remove your keyboard.
So now your can remove just your keyboard slowly for some connectors on the motherboard then clean it with a tooth brush.
You can only clean your keyboard with a toothbrush without rmoving it,
Try to remove the space bar key and clean under it.
Try to hard press the space bar for about 5 times, it can release the pusher under the key.
it some liquid was spilt on it you have to remove the keyboard and clean the plastic under ther keyboard.
Good luck
Jan 20, 2011 | Computers & Internet
I took my spacebar off to clean it and i dont know how to put it back on?
There is a rubber part that is designed to spring up when you release the space bar - this is the contacts that is the electrical push button. At each end the metal bar is hooked to the plastic (the long space bar key). There may be a couple springs found as well - they should seat on the base. Connect all pieces and place the space bar key over the area where it aligns to the keyboard and snap it place with a slight force.
Nov 23, 2010 | Compaq Keyboard
Space bar sticks
If you can get the space bar button off without messing up the button or the tactile underneath it then get if off and with a damp cottonball with glass cleaner wipe off the button and then wipe off the area where the plastic tactile is. As long as you can press on it and have it go down and come back up then the tactile and area is clean.
Important thing will be to get the button to go back on properly.
If your having problems with getting the button off and don't want to go thru the cleaning process then replacing the keyboard would be the 2nd option.
Jul 06, 2009 | Fujitsu LifeBook T4210 Tablet PC
Onmydelllaptop,thespacebarwillnotspacenormove
The rubber plug below the spacebar button is faulty.The button needs to be removed gently and the rubber plug below it which touches the board below should be cleaned.If this does not solve the issue the rubber plug below the button needs to be replaced.Its a common problem.
thanks and please do not forget to rate the solution.keep updated.
May 19, 2009 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
What is the function of the button below the space bar
Thats touchpad locker - when you using keyboard with both hands, you can lock touchpad from accidental touching and moving cursor.
Mar 12, 2009 | HP Compaq Presario CQ70120US Notebook PC
Mx3200 First the spacebar won't work andthenitworkstoowell.
did you check to make sure that the springs and bar under the spacebar are seated correclty?
Sep 30, 2008 | Logitech 967437-0403 Keyboard
Compaq presario v6000 laptop powering down with no warning
If not, then the keyboard cable has probably come loose.
Look for some way to remove the keyboard. Sometimes a screw from underneath, sometimes two or three small catches at front of keyboard (small gaps in metal plate in front of space bar). Sometimes top plastic bar above keyboard slides sideways.
Keyboard cable uses goes into a header socket - to refit:
Switch off and remove battery and power first!
1. Prise up each end of the socket with a blunt knife - the outer part of the socket should move up a few mm
2. Push keyboard cable down fully
3. Push down each end of the header socket so it is flush with the lower part of the socket.
4. Test keyboard
Aug 20, 2008 | Compaq Presario Notebook
Compaq Keyboard Logo
215 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
