Question about Kitchen Ranges
Oven temp will not go above 300 degrees - Kitchen Ranges
  • 454 Answers
You need to check the thermostat in the oven. Go to your manufacturer's web site and download the technical manual for your stove. There should be a troubleshooting section in the manual. If not, and you are somewhat handy...
1. Disconnect the power from the stove.
2. Locate the thermostat and jumper it out.
3. Reconnect power to the stove and turn on the oven.
4. Wait a few minutes and see if the temperature goes above 300 degrees. If it does, replace the thermostat. If it does not, order a service call.
Don't forget to shut off the power again and remove the jumper.
Posted on Oct 05, 2009
3 Suggested Answers
Greg20
  • 149 Answers
SOURCE: Amana electric oven won't get above 225 degrees.
sounds like only the broiler is working which comes on low during bake cycle. unplug or turn off breaker, remove bake element and check for continuity or take to someone who can.
Posted on Jun 13, 2009
  • 969 Answers
SOURCE: I have a GE XL 44 gas oven. The oven does not
REPLACE HEAT SENSOR
Posted on Nov 12, 2009
Why won't the fan switch of after the oven is switch off
Not sure what fan your question refers to, but the fan that removes the heat from above the oven is controlled by a thermostat. It normally does not come on until the air temperature above the oven space is about 300 degrees and does not turn off until it is below 300 degrees.
Feb 25, 2015 | Ovens
Convection oven not working properly???
your correct the only difference between a regular oven and a convection oven is that it has a fan.when you open the oven door the fan should be spinning to a stop if this is not the case you may have a problem with the fan.
Aug 14, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Whirlpool super capacity 465
Seems the thermostat is malfunctioning...thus when baking at 500..thats quite high...it keeps getting hotter past that point to where the oven thinks its in self cleaning mode. Also seems like the problem because when it cools down your allowed to use it again. There is no way to test it with an ohmmeter. Just remove and replace.
Nov 30, 2013 | Ovens
Oven, model number 3510PRW does not reach the temperature dialed. To get to 300 degrees I have to put it on 500 degrees. Thank you for your help!
Either 2 thing can go wrong
1. you temp sense probe is failing
2. you temp offset on your dial got loose, or your knob is messed up
Dec 18, 2010 | Magic Chef Ovens
Oven does not "burn" steadily when set below 300 degrees.
Sounds like you have a bad oven ignitor and oven burner tube. install a Amperage meter on one of the oven ignitor wire, It should draw above 3 AMPS, if it is below then you have a bad oven ignitor, or just change the oven ignitor to see if it makes any difference. Have fun.
Dec 28, 2009 | Dynasty DGRSC 30 Gas Kitchen Range
My gas oven will not heat up above 300 degrees and
You may have 2 problems.
One. The temperature sensor could be bad. You can remove the temperature sensor and check it with a ohm meter. It should read 1050 to 1150 ohms. If not. It is bad.
Two. The glowbar ignitor could be bad and not igniting the gas safety valve.Open the bottom drawer of the oven and set the oven to bake. The burner should light in 60 seconds or less. Re-light should be about 30 seconds or less.
If it takes longer the ignitor is bad.
Dec 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Mar 14, 2009 | Ovens
Oven will not heat past 300 degrees
300 far. or cels if its celcius its to high they should run at about 260 or the high temp sensor will shut it down how fast is your belt running it should be 6.30 to 7.00
Jan 28, 2009 | Lincoln Conveyor Oven - 1133-000-A
Sharp R-1874F Low Convection Temp
We have the 2 service manuals you need to refer to for this model and have uploaded them to our site here and here to help you.
You will need the
free Acrobat Reader to view or print them in case you don't have it.
The manuals have a safety info, disassembly info, troubleshooting chart, test procedures, part numbers, etc.
I would first suspect a bad thermistor, but it should be checked, as well as the line voltage at the outlet, etc.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Jan 08, 2009 | Sharp R-1874 Convection/Microwave Oven
Kitchen Ranges Logo
171 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
