Question about Frigidaire Washing Machines
Fridigidaire top load heavy duty 7 cycle washer fwx223lbs5
It cuts on and off during spin cycle
Oceti
  • 51 Answers
SOURCE: Older Maytag Washing Machine - Top Loading "Heavy Duty" model
There is a screw near the base of the agitator. If it is missing replace it with a stainless steel screw. If this is a machine that is older than 25 years, you will have to replace the rubber ring on the agitator shaft.
Posted on Dec 07, 2007
SOURCE: agitator will not work on wash cycle
Order the upper aggitator clutch/dog kit $15. Now top half of the aggitator is doing its thing just like the bottom half. Hope this helps someone else too.
Posted on Oct 28, 2008
landsend
  • 1066 Answers
SOURCE: Squeaky washer in spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
How good are you and your tools?
Posted on Apr 01, 2009
t00nz
  • 4738 Answers
SOURCE: Vibration during spin cycle - "walking" across floor
Front loaders are prone to vibration problems. Don't want to go into the technical details of why, but it's important that they're placed on very solid surface (preferably concrete), and checked that their feet have been adjusted so that the machine is level. Unfortunately, most people don't have a concrete pad for their washer. The next option to consider is to provide dampening of the vibrations. This can be done very simply as this one fellow demonstrates. The main thing to keep in mind with this solution is that it is merely trying to dampen the vibrations. Don't be too forceful in your own solution (think lightly touching the top of a vibrating tuning fork with your finger to stop the tone).
Posted on Sep 18, 2009
  • 64 Answers
SOURCE: Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Posted on Sep 21, 2009
Spin cycle does not drain water. The washer just stops when it gets to the spin cycle. The washer is a 70 series heavy duty.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 30, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine won't spin dry . Its a whirlpool 2 speed 7 cycle heavy duty model
If this is a top load clothes washer, almost all units will not spin if the door is open during the cycle time when it should be spinning. If the door is closed, check if the door safety interlock is broken (on most washers, you will see a pin on the door pressing into a little depression)
If these things check out, you probably have a failed transmission deep inside the clothes washer. Fixing that is non-trivial.
Aug 20, 2009 | Whirlpool Washing Machines
Mar 27, 2009 | GE WBSR3140DW Top Load Washer
Squeaking Washer
did you remove the shipping pins pins when you installed it
Jan 04, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
175 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
