Question about Garden
Have an RT 160 M&W 3pt tiller with 4 tines (teeth) per rotor, but there is room for six. Question if going to 6 would be smoother operation or ''not a good idea''.
pranaclimbin
  • 50 Answers
SOURCE: Yard Machines/Tiller
the tines are usually connected with shear bolts designed to break away when u hit something as a safety precaution so that u dont break anything in the transmission. its common that people dont know this and replace them with normal bolts. if this was done and the tines are not moving now chances are uve got a snapped gear shaft
Posted on Dec 04, 2008
trippssmengi
  • 76 Answers
SOURCE: Craftsman Front Tine Tiller 6.0HP/26" -- can not start it
First check for spark, if you have spark than you can try spraying a little fuel into the carb and try to start it if it starts then dies its the carb
Posted on Dec 27, 2008
SOURCE: craftsman front tine tiller 917.299011 parts
If you are looking for repair parts diagrams and part numbers they are located pages 38 through 45 of the Owner's Manual.
Hope this helps.
Posted on May 26, 2009
SOURCE: Honda GX25 HG110 mini tiller, tines won't turn.
Mine did the same thing....two things to check: 1) air cleaner, make sure that it is clean 2). gas filter in the gas tank. Take a short piece of wire and fish the black line out. On the end is a small fuel filter. After I flushed mine fuel filter out it ran fine.
Mark
Posted on Jun 01, 2009
SOURCE: Yardman Rear Tine Tiller tines won't turn. Belt
The problem lies in the shift lever in the gearbox. A poor initial design that was upgraded twice. The shift fork arms have spread enough for pins to come out of the groove they run in when the tiller is shifted to the last position. (Bending back into position would only be a temporary fix as would not be any stronger.) To replace shift lever, the gearbox cover has to be opened. Seperating the cover can be somewhat challenging. When prying cover apart try to not damage the cover gasket. Gearbox grease is very thick, so gasket's real purpose is to keep water and contaminants out. Leave all gearing and chains in place. The shift lever part number is 618-0245B. Or use assembly kit number 753-0869 (contains shift lever 618-0245B, position indicator, and roll pin.) Part will run in the $56-$68 range and can be found through MTD as well as Cub Cadet. Also can get through Sears PartsDirect.
Posted on Dec 13, 2009
How easy is it to replace clutch cable on earthquake mc 43 tiller
Remove the 4 to 6 screws holding the engine to bottom gear box and lift eng off. clutch is right there. It could be the teeth on the lower branze gear are stripped. lay machine on its side and with tines off remove gear box cover.
Apr 08, 2013 | Ardisam Inc Earthquake Mini Cultivator
How to operate sears5 hp rototiller. Especially the gear shift. Has reverse
Hi and welcome to FixYa, I am Kelly.
Find the long model number on your tiller. Then go to this site: http://www.managemylife.com/mmh/owner_manuals
Enter your model number and searh for you manual. When the manual is found click get manual or rt click the manual you want Owner, Engine, or parts and download it. The instructions will be in the manual.
This is an example of a model number: 917295852 and the manual for that rear tine tiller is here:
http://www.managemylife.com/mmh/owner_manuals/86874/CRAFTSMAN-Rear-Tine-Gas-Tiller-1006404L?brand_name_search=917295852
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Mtd Garden
MTD Tiller
Oh, I hate to hear that. Most likely you will have to get into the gearbox to see what is going on. It really isn't that hard but it is time consuming. Make sure you pay close attention as to how you disassemble it. Good luck and let me know if I can help further.
May 15, 2010 | Mtd Super Bronco Rt Tiller
I have a Ariens tiller model #901001. The rear
YOUR PROBABLY HAVE A GEAR CHEWED UP?CONTACT CHOOCHOOPARTS.COM FOR DIAGRAM? DID YOU CHECK OIL...IF OUT OF OIL IN REAR TINE TRANSM ...YOU CHEWED UP THE BRASS GEAR ....I REBUILT MY MAIN TRANSM...EASY TO WORK ON...AWESOME MACHINES.
May 04, 2010 | Garden
MTD Tiller
This is another gearbox failure and seems to be quite common. You will have to remove the gearbox from the engine, open the gearbox up and inspect. Make sure you pay attention as to how it all comes apart and maybe even take close up pictures as you go. I hope this helps you.
Mar 28, 2010 | Mtd Super Bronco Rt Tiller
Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
May 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Manual needed
Hello;
You might want to try the web site "ManageMyHome.com".
That's where I found my manual for my tiller.
Hope this helps you.
Jeff
Apr 03, 2009 | Garden
Sep 28, 2008 | Mtd Super Bronco Rt Tiller
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
