Question about GE Advantium 120 Convection/Microwave Oven
GE Advantium Monogram, model# ZSC2001CSS02. Turns out the cooling fan for the magnetotron wasn't coming on because of a bad relay on the main control board. When the magnetotron overheated a safety kicked on which tripped an internal relay and killed power to the unit. How much is it to get serviced and replaced if out of warranty?
MicrowaveSvc
  • 9098 Answers
SOURCE: Complete Shut-Down
I woulds first suspect a blown internal fuse or a thermal cutout on the magnetron in your case, but a microwave can be dead for many reasons.
If it goes dead for just a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power on again.
If it's intermittent or random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Posted on Nov 25, 2007
  • 43 Answers
SOURCE: Oven stops after a few seconds
I like the information you give.
If the unit will work with the control Panel at a 45 degree angle it tells me you have a loose connection. The 45 degree angle puts enough pressure on the connection to keep it completed. With the Control Panel in it's normal position, the loose connection Heats and Opens the connection. After it cools connection is again made until it Heats up again. Remember Expansion, Contraction. I do not believe you have a Magnetron issue!! A Magnetron does not know if the Control Panel is at an angle.
Can you hear a slight "Click" when the unit shuts down? If so this is a relay opening. When you say you replaced the Control Board. Was this the Control Panel PC Board, or was it the Cook-Relay Control Board? A Door Switch not making solid contact can do this. Is your Door latching down solid? Check for loose connections, not open LOOSE.
Posted on Jan 28, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: replace inside bulb
There is a step-by-step guide with photos here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Advantium SCA1000 not heating
That would be 'the primary interlock (top door switch), or its mount may be loose or cracked.
It may be a coincidence, or not. Hard to say.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
But it could be misalignment from the door work. Too bad he didn't just replace the door handle. That's such an easy job.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
It's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Jan 29, 2009
SOURCE: control panel "locked" on ge advantium 120
You might have set the child lock. Look in the manual. It is on P.36 in my manual.
Posted on May 16, 2009
INSTAL A NEW DOOR ON ge zsc2001css02
You can find helpful exploded view diagrams and order parts and accessories by entering your full model number from the tag on the oven here.
Dec 03, 2013 | GE Advantium 120 Convection/Microwave Oven
GE Advantium Oven Noise
Most are eqipped with a small cooling fan that allows the unit to cool down quickly..fan may need replaced
Jun 07, 2012 | GE Microwave Ovens
I have a GE Advantium Microwave Model # SCA1000HWW, where the lights stays on, the fan is on and the turn table is spinning when you shut the door.
Main relay RY1 on your main PCB is shorted.
You can order a new board (part number WB27X10776) for $167.20 from the Pros here. They're our favorite supplier.
Or we can repair your circuit board with our $39.95 service.
The service manual will help you with disassembly. It's here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly if you need further help.
Jun 20, 2011 | GE Advantium 120 Convection/Microwave Oven
Fans and lights don't work on our Advantium sca2000bbb. Display does. The main fuse is OK. Is there another?
Some relays must have got stuck open. Check the following schematic. You should check the Main relay, RY14 and RY15 for lamps and relay RY6 for the fan.
http://www.microwavedisplay.com/advantium_sca1000_sca1001_sm.pdf
For your own safety, always make sure you are working safe. Microwave units can be very deadly. Consult an expert if in doubt.
Jan 04, 2010 | GE Advantium SCA2000B Microwave Oven
GE Microwave Profile Spacemaker Runs on its own
Your microwave turning on by itself is a "self preservation feature" of the GE Profile Advantium and maybe some other models. Read the manual, When your over the range oven gets warm enough, for whatever reason the venting fan comes on until a satisfactory oven temperature is reached. You are not permitted to shut the vent fan off. Also it seems a temperature near room temp must be achieved before it shuts the fan motor off, it is very annoying. We had to return our Advantium because of fan noise. I configured the ovens vent fan to the recirculate direction because we do not have a vent duct that exits the house over our range. When the vent fan acting as the ovens cooling fan automatically turned on we would have to leave the house to hear each other talk. Too bad we really liked the oven other than that major problem. G-Man
Apr 19, 2009 | GE Profile Spacemaker Over-the-Range...
G.E. convection oven fan stoped working. The fan turns freely with no resistance.
Does it have 110 volts on it? If so its bad.
If not then look for a bad relay.
Jan 14, 2009 | GE Advantium 120 Convection/Microwave Oven
Sensor error and periodic beeping for Advantium 120
If the internal cooling fan does not come on when you're microwaving, the magnetron will overheat and the thermal cutout will be tripped, causing the oven to go dead until it cools back down.
If this happens more than a few times, the magnetron can be damaged.
If the turntable is not turning (assuming it's not set to be off) when you're microwaving, then the problem lies on the relay circuit board (sub PC).
If the turntable is wokring and the fan is not, then the fan motor or wiring is at fault.
At this point, with such odd problems, I recommend that you contact GE customer service for your nearest GE-authorized service center
GE Customer Service is here.
Good luck.
Jan 10, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave function not working properly on GE Advantium SCA2000BCC03
I assume you're talking about the internal cooling fan, which should always be on when you're microwaving.
If it is not coming on, the magnetron can be destroyed from overheating!
The turntable and and cooling fan are both controlled by relay RY17 on the main circuit board.
We regularly repair these control units for customers nationwide with our guaranteed $39.95 service in about a week.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
Sep 24, 2008 | GE Advantium SCA2000B Microwave Oven
Advantium 120 Keeps running
I've got this problem also.
The interior light on the oven died. We replaced it. Since replacing it the light stays on and the turn table turns.
Looking at the diagram, the "main relay" is what powers both. My guess is that it's stuck in the "on" position. Solution will be replace the relay.
Long term fix may be bigger relay.
Jan 26, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave cooked dinner and now does work
I had the same exact problem -- turned out the cooling fan for the magnetotron wasn't coming on because of a bad relay on the main control board. When the magnetotron overheated a safety kicked on which tripped an internal relay and killed power to the unit. GE repair guy diagnosed and resolved the problem. Only snag was that they didn't have a spare board so I had to wait a few days for them to deliver a replacement and for the guy to come back and install it. Now has been working for 5 days... of course I probably jinxed myself now! :)
Dec 18, 2007 | GE Advantium SCA2001BSS Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
153 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
