Question about GE Spacemaker JVM1640SJ Microwave Oven
Made a crackling noise and smoke came pouring out of the side.Stoped it and opened door. Very hot on top inside and still making noise as if wiring is burning. Smells of burning plastic? Had to unplug it!! Is there a recall? the model JVM serial # HZ
    President:
  • GE Master
  • 1,922 Answers
Your hi voltage transformer or magnetron tube are burning up from too much current draw from the mag tube
Posted on Oct 05, 2009
Panasonic microwave model NN-H275: Oven door doesn't open; Makes crackling or arcing sound when turned on;
If you do not see actual arcing in the cavity making the noise it is probably components on the inverter. Too exppensive to repair. Get a new one. Dont like or trust the inverters.
Jun 25, 2017 | Panasonic Microwave Ovens
Making humming noise when plugged in. won't stop until I open the door. underneath light doesn't come on. right front corner inside of the microwave gets hot. replaced turntable motor same problem
Sounds like the vent to the outside is rattling or not secure or the door seal is not sealing properly. let us know Bruce if you need parts or anything else. thank you and leave feedback
Jul 13, 2016 | Microwave Ovens
Mx 100 subwoofer repair
open the microwave door, look for a silver rectangular plate inside,try cleaning the plate with a damp cloth.
Oct 18, 2013 | Microwave Ovens
My microwave oven heats, but makes strange crackling noises. Is it allright to keep using the unit?
No. Please have it checkd as it is dangerous to let the high voltage jump along side the magnetron. This will eventually result in the failure of the magnetron with a possible damage to the circuits.
So open and check if there is any foreign particles/insects struck within , Is the insulation damaged or remove the magnetron and clean the uni , clean the cabin specially if food haas accidently got spurted inside, dry the whole unit after cleaning before you fix back the magnetron.
The microwave must now work without crackling or else if the spark is seem near the magnetron , it must be replaced.
Hope this advice helps.
Aug 27, 2010 | Microwave Ovens
When I put a bag of popcorn in the microwave, it started but noticed it was making a funny noise so I stopped it and opened the door and there was a little bit of smoke coming from the side wall and it...
The first thing I would do is thoroughly clean the inside. Take particular care when cleaning around the upper left side. Sometimes a buildup of food steam or spray can cause the problem you are having. Never spray anything into the microwave, in an attempt to clean it.
Hope this helps.
Jan 20, 2010 | Bosch HMB402 Microwave Oven
Smells like burnt wires
It is very possible it may have burnt wire or burnt capacitor. Remove unit, remove top cover and look inside to see if you see any burn marks or burnt wires. Also check fuse to see if it is good or not.
Aug 07, 2009 | Whirlpool MH1141XM Microwave Oven
GE SPACEMAKER JVM1650 ''MICROWAVE MAKING LOUD HUMMING NOISE AND INSIDE REAL HOT WHEN DOOR CLOSED''WHEN DOOR OPEN DON'T HUM
When door open the microwave should not work at all, if the turntable and light come on with the door open , if they do , then this is an additional problem with door switch and must be fixed.
Regarding humming noise and no heath, Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Apr 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
FLASHES INSIDE OF MIRCOWARE AFTER IT IS STARTED AND MAKE NOISE
It could be a magnetron sparks to the open metal inside the m/w cavity or some broken wire on high voltage side. It is not HV transformer (when burn create a lot of smoke and bad smell). Magnetron needs to be replace.
Dec 03, 2008 | Whirlpool GT1195SH Microwave Oven
Kitchenaid model KHHS179LSS Microwave oven handle replacement
There is a pin holding the door on upper right hand corner of the door. Holding the door in the open position, lift up on the door a little and remove the pin. The door will come off. There are two screws on the edges of the door on the end where the handle is located. Remove the screws. Now, Take a slim screw driver, and carefully pry between the inside door panel and the ourside door panel starting at the end where the door handle is. Lift the inside of the door out. The opposite end of the inside door panel will come out last. Believe me, this works. Getting it back together is a little bit different, but it snaps back together without using tools. Just put the inside of the door back by laying it down with the handle side down after you have replaced the handle of course. Now, pushing in on the inside of the door panel starting on the handle side, start with lining up the panel and push gently. It will go back into place much much easier than it comes out.
Jan 27, 2008 | Microwave Ovens
No heat
Magnatron is suspect. Need to put a voltmeter and see if the input (primary) side to the high-voltage transformer (big heavy iron thing in there) is getting 120Vac. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing the magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Dec 28, 2007 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
502 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
