Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
Adapter is not lighting up or finding signal - NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
    President:
  • 1,187 Answers
NetGear's offical response:
http://kb.netgear.com/app/answers/detail/a_id/17/session/L2F2LzEvc2lkL0JyNEJqQ0pq
Here are thye latest drivers for your computer / OS
http://kb.netgear.com/app/products/family/a_id/1268
1. Do not use a USB cable with this adapter.
2. Try every USB port on your computer.
Posted on Oct 05, 2009
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always) Pay attention to item 1,2,5.
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Trailer lights come on when van lights are on but turn signals don't work.
The turn signal bulb circuit on the trailer MUST match the towing vehicles turn signals. Example: Tow vehicle turn signal light is the same bulb as the brake light, then the trailer must match. If the tow vehicle has a separate turn signal (amber bulb located away from the brake light) then an adapter is available that will send the correct power to the trailer so everything works correctly. The adapter can be found an auto parts stores, RV supply stores and some truck stops too.
Nov 15, 2015 | Cars & Trucks
Need help puttin on a trailer plug on 2002 suzuki marauder
You can pull all your power from the rear tail light! You'll need a multimeter(Or at least a test light of some sort!) on your adapter you'll have a green, a yellow, a brown and a white wire.
White- is your ground(Find a good clean nut/bolt on your frame)
green- Right turn signal/brake light
yellow- left turn/brake light
Brown- tail lights
What you'll have to do is find the wires for the tail light on your bike, And one by one probe them(with your multimeter/test light) With whichever accessory on(E.G. turn lights on, then probe the wires until you find the one that has power, This will be your tail light wire. same with both of your turn signals and brake light!
May 30, 2012 | 2000 Suzuki VZ 800 Marauder
I have several computers in my house, and just purchased a Netgear N600 High Performance Router. All computers easily pickup the signal and connect to the new router. However, one of my computers using a...
you might try moving your computer closer to your router
make sure your routers and your dell 1450 settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet if applicable
hope this helps
Jan 26, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
BT HomeHub wireless router which cannot connect to the XBox 360
your router may have incorect connection settings. what i mean is that your router may have security on that rejects connecting to adapter. check if the xbox can connect to the internet via ethernet cable. this will tell for sure if the 1 the adapter cannot read the signal or 2 the adapter is not able read any signals. to test if its the adapter, try searching for other signals.if you find any other signal it means your router. is rejecting to send the signal to the xbox.
Feb 01, 2010 | Microsoft Wireless Network Adapter Xbox...
I just purchased wireless adapter for xbox and wireless system linksys. The light on the adapter was initially green but then changed to red and will not go back to green. Is this a problem I can correct...
Hi! dont worry about the green and red lights on the wireless adapter, If you are getting a green, it means that you have an excellent signal but if the light blinks on red, it means that ur signal is not steady and trying to get a stable signal.. that is normal on a wireless card..
Aug 02, 2009 | Computers & Internet
My netgear adapter sometimes cant find my 2 wire dsl signal
What signal strength do you get when you connect?
Is the router buried underneath or inside a cabinet or anything?
Consider relocating the router away from other objects (particularly metal items), or on the outside of any type of cabinet.
Jan 23, 2009 | NetGear WG111 802.11g/b Wireless Adapter
Signal dropping out when useing netgear adapter
You may find that either the signal strenf=ght is not there or there are other devices near by on the same channel as the router.
Use THIS app to test the signal strength and check the channels is use also
You may want to either move the router to a higher postion (on a shelf) or get an external antenna for it to boost range. Be aware that cordless phones are a source of interferance so thias may affect signal strength, reception etc. Put some distance between such devices and the router/widfi card etc.
Jul 06, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Xbox 360 wireless adapter not finding network
Hello Sir,
Reset your AX by holding a pin or pen tip and count to 20.
Plug Airport Express
Wait a few minutes
1. Open Airport Utility
2. Manual Setup
3. Airport Icon -> Wireless Mode -> Join a wireless network
4. Network Name -> Enter the SSID of your Linksys router
5. Choose the same wireless security that you are using on your Linksys Router
6. Wireless Password -> Enter the wireless key that is on your Linksys router.
In the Music Icon, you should be able to find "Enable iTunes"
AX will continue to blink for a bit, perhaps a minute, while it searches and connects to the Linksys Router.
Should turn green.
Good luck.
Don't Forget to rate the solution
May 12, 2008 | Microsoft Wireless Network Adapter Xbox...
Encore modem
As far as I've seen, the data line light on the modem should indicate whether the data signal is coming through from AT&T or not, so I'd suspect that there is a problem with the signal from AT&T rather than between your modem and computer.
It is possible that the data signal lapsed for a while and your modem thinks it's still not there without actually looking. You can try unplugging your modem from it's power for about a minute (at least 30 seconds) and then replugging it in afterwards. That sometimes allows it to see the new data signal if it lapsed previously for any reason. After all lights light up (especially the data one), then try to go online again. If that doesn't work, try restarting the computer and if that doesn't work I'd try to talk to someone higher up in the AT&T support and explain about the data signal not showing on the modem so you can get them to fix it.
Hope that helps! :)
-Aloha!
Mar 19, 2008 | Encore ENP832-TX-PCSU PCMCIA Network...
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
222 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
