Question about Maytag Atlantis MDE6400AY Electric Dryer
Coins stuck in tumblers on my Nebtune Dryer
How do get coins out of my dryer?
  • madathusband May 25, 2008
    A small golf penci got sucked into the exhaust grill. How do I get to it?
  • 38 Answers
Try calling a local repair man they could probably take it apart and take it out.
Posted on Dec 22, 2007
Speed queen commercial dryer model sdg109wf, the coin compartment is stuck because of compartment was full, after emptying the coin slider doesn't come out so we cant use the dryer. what is the...
Oh your bringing me back to the early days of my appliance repair career when i only serviced coin operated washers and dryers. Not in the coin box but the cover on top where you would get access to the timer is a bolt that holds the coin slide to the coin box asm. remove that bolt(if i remeber from 25 years ago its a 5/16th inch hex head and brass colored) and the coin slide will come out and then gotta kinda genlty presuade it in with a hammer so the coin will drop through or pull on the handle ya would push, to free it up and remove stuck coin
Aug 20, 2011 | Dryers
We have a bosch front load stackable dryer that has coins stuck in the things that go around in the dryer, can we get them out?
You'll have to remove the top panel so you can loosen the baffles and get your coins out. Either that or take the back panel off and remove the drum altogether, which ever you find easier.
Jul 08, 2011 | Bosch Nexxt 500 Dryer
The tumbler makes a terrible noise - I'm sure it's just a coin or a screw rattling around in there. I can't figure out how to get inside to look around the tumbler to see what it may be. And once...
Open the door and look inside - yes, you can see everything inside the drum. Sometimes buttons, especially the metal ones on denim pants, can make a pretty good racket.
If you don't find any foreign objects inside the drum, and the dryer makes noise even when it's empty, it may be time to change the drum rollers or the belt tensioner pulley. It's also remotely possible that there's something batting about in the blower housing, but if that is the case, it would probably be a screw or something broken off of the ductwork, or the blower itself is loose on the shaft. Post back if you need instructions for checking the mechanism underneath the drum.
Nov 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The dryer when started sounds like theres a rock rolling around in it, Doesnt seem to dry the clothes.
You will need a qualified LG technician to diagnose your problem. They will have to disassemble it and see what the problem is.
Good luck.
Sep 22, 2010 | LG DLG5932W Gas Dryer
Coins stuck in Maytag Atlantis dryer. Could
. U1. Unplug the washer.
2. Using a stiff putty knife, press the locking clip in the seam between the “hood” and front panel, as shown below. There’s a clip on each side. Raise the top panel up and out of the way. You may want to tape the the lid to the top panel so it doesn’t slam into the wall, thus evoking explicit language.
4353551224_4d366b181c_o.png Now you’ll see two screws, one on each side. Remove ‘em and pull the top of the front panel out toward you. Then just lift the panel off the bottom hinges and there you be.
4353556628_0370cd3f5a_o.png Ain’t nuttin’ to it. Now whup up on that bad boy! fouetaa.gif
Apr 18, 2010 | Kenmore 74602 Gas Dryer
Dryer makes a humming sound and nothing else
Sounds like your tumbler motor is stuck. Try moving the inside of the dryer. Does it turn freely? If it does then the motor could be defective. If not the dryer tumbler could be jammed.
Dec 19, 2009 | Whirlpool Dryers
Maytag 3000 series dryer, coins stuck in dryer fin
open the top of the dryer. slide the belt down to the power unit. of course you shoudl always unplug the unit first before removing the cover. carefully lift up ont he drum and they shoudl fall out. carefull y palce the drum back and the belt. replace the cover and plug in to see if that works.
Dec 04, 2009 | Televison & Video
Hoover 5020D Dryer door won't open... button is
You probably have a coin or other metal object stuck at the bottom of your dryer door preveinting it from opening. Take a table knife and see if you can push the object upward to allow the door to open..
Jul 29, 2009 | GE DBXR463EDWW Electric Dryer
Coin-operated dryer won't turn off at end of cycle.
A dryer timer is a real simple device. Take the whole thing out and give it a good inspection. A little wd 40 can do wonders. A bad coin in the works can jam it on. Put a coin thru the works, watch the action. The timer motor can fail or get stuck, spray and test.
Apr 22, 2009 | Maytag PYE2300AY Electric Dryer
Frigidaire dryer model number LGQ1442ES0 won't stop spinnin
Ive seen this before. There was actually a coin that had fallen out of the drum and got stuck on one of the contacts, causing it too short. Open the dryer panel, unplug it first, and look for any signs of a coin or somthing shorting a circuit. Thats step one. Hope this helps. Dave www.washermd.com
Dec 17, 2008 | Whirlpool LER4634J Electric Dryer
Maytag Atlantis MDE6400AY Electric Dryer Logo
337 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
