Question about Kenmore Dryers
F40 error - Kenmore Dryers
    President:
  • 1,304 Answers
Model number please ?
Posted on Oct 05, 2009
  • cknowles1633 Aug 09, 2010
    Model # 110.67092600
Kenmore elite dryer. model 110.6708 or 09. check lint screen light is on. I have cleaned inlet/outlet/screen/front and back. unit will start but will not heat. if in the normal setting the f40 code wi
The F40 error code indicates a communication failure between the main machine control board and the motor control board for the blower motor on the dryer.
This can be caused by a loose wiring connection or a blown fuse.
Nov 22, 2012 | Dryers
I am receiving a f40 code on gas dryer
F40 is a error that appears between the machine control and the motor control when communication becomes lost. Check the connection between the two. The error codes whould be on the tech sheet beneath your console panel along with how to check for this error.
Aug 03, 2011 | Dryers
Dryer wont run gave me f40 code, can you help me?
I found two possibilities for an F40 code.
1) Error Code F40 is that the thermal fuse has blown.
2) The F40 error code is a communication problem between the machine control board and motor control board. A bad connection might or might not cause this.
Dec 23, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Model 110.78082701 F40 error code what does it tell is bad?
F40 is a error that appears between the machine control and the motor control when communication becomes lost. I had this same issue. My dryer would run and heat up but then stop and give me the f40. I measured all thermisters and everything was in range. The tech sheet stated that I needed to buy a new control board and I did. Same problem.
The solution was a loose connection on for p4. I took needle nose pliers and squeezed the connector to make it fit tight on the board and everything is working now.
Bottom line, expensive dryer with cheap connectors.
May 11, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
Got F40 error code self-cleaning my 790.9642 Kenmore range
try this, after several calls I finally found out what the code meant. code meant. Power supply issues, not necessarily with your power supply but with the appliance2_bing.gif itself. Of course they want to send a technician for $65.00, which may be worth the headache. All someone told me was to turn off the power braker for 2 hours and try again. Yeah right, after 2 hours of heating your house and paying the electric bill, but when breaker is off there will not be any electric used. code f40,
Apr 18, 2010 | Kenmore Kitchen Ranges
Panasonic scanner kv-s3065c error code f40-30000000 hopper error ocurred in scanner
F40-30000000 Solution You have to replace under the hopper cable part number PJJEC3437Z and board part number PPB747ADF25H from www.partstore.com this will take about 2 hours to do because of the covers you have to take off.
Apr 06, 2010 | Panasonic Office Equipment & Supplies
My Kenmore Oasis Dryer will not run and has an F 40 code. What is wrong with it?
Get the model number and go to:
http://www.searspartsdirect.com/partsdirect/modelHelp.pd?pop=flush&modelNumberId=18
The F40 code can mean a thermal interrupt or a loss of connection between the control circuit board and the motor circuit board.
Perito posted this on askmehelpdesk.com:
If you post your model number, or download the owner's manual from the above link, you'll probably find out what it means, at least.
Dec 12, 2009 | Kenmore Dryers
I need to reset the entire program on the f40. System settings and all
The EASY but Time consuming way (If you Only hagve USB 1), is to just RESET the unit.
The manual will run you through it, and reload.
I have both Gigabeat Room, and Win/Player 11, and have reset and reloaded a few times.
Just take some time (Specially with Gig Room)
Good Luck
Jun 13, 2008 | Toshiba Gigabeat F40 40 GB MP3 Player
Dryers Logo
80 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
