Question about Nintendo DS Lite
Replaced shell on DS Lite, after when turning on, green light comes on, screen flashes and DS shut down. What could be the problem?
Maybe a wire got connected wrong in the reconnection process. Maybe you could call or go to Nintendo support.
http://www.nintendo.com/consumer/
Posted on Oct 27, 2009
My son's DS Lite stopped working last night. The unit was working fine and the battery light turned red so he put it on to charge. After about an hour the light was green so he tried to start the console...
It sounds like the battery is dead. You can order a replacement battery direct from Nintendo at http://store.nintendo.com/webapp/wcs/stores/servlet/ProductDisplay?productId=108205
Jan 27, 2014 | Nintendo DS Lite Console
My problem is that every time I turn on my ds lite the white light flashes and then it shuts off and it's fully charged.
Hi the solution to your problem is
A failed top screen the ribbon had gone
The green light comes on screen flashes an then goes off
I repair nintendo ds lites in the uk
So can sort you out for a reasonable price
Apr 23, 2011 | Nintendo DS Lite Console
Power led lights green, touch screen flashes white and powers off
try taking it apart again and checking closely to see if any inner cable is loose,
Apr 13, 2010 | Nintendo DS Lite Console
My DS wont turn on so I try to charge it the orange light comes on but eventually it turns off an suggestions?
When you say it doesn't turn on does the green light come on at all?
If the green light stays on for 1-2secs then you should see one of the screens flash, if that happens then you will need to replace the screen that doesn't flash. If you need to replace the top screen follow this guide, or if you need to replace the bottom screen follow this guide.
If there is no green light at all then the chances are the "F2" fuse has blown. To replace the fuse follow this guide.
If you need help taking the DS lite apart follow this guide.
The guides are written by me so if you need any extra help or if you have any more questions don't hesitate to contact me.
Hope tis helps.
Regards,
SOD69
Feb 11, 2010 | Nintendo DS Lite Console
I turn My nintendo DS lite on and after maybe 2 seconds the green light flashed and shuts off. Help!?
Do either of the screens flash just before the green led goes of?
If it does then the screen that doesn't flash is faulty... If you have a warranty then i'd suggest sending it in for repair if not and you fancy a go at a bit of DIY let me know and I will take you through the process of dismantling the DS lite, reconnecting the screen to see if its just come loose and if you need to I can tell you how to go about fitting a new screen.
Hope this helps,
Regards,
SOD69
Feb 02, 2010 | Nintendo DS Lite
Nintendo DS Lite, Dim Green Light, Brigher Green Light then off
If the green light reacts as you state then the chances are the fuses are fine.
Again, with the reaction of the green light being as you stated i'm going to assume you have a problem with one of your screens, tell me... when the green light comes on does one of the screens flash? If it does then we have found the answer...
The screen that doesnt flash is the one with the problem, you can try taking the DS lite apart and re-connecting the screens ribon to see if that sorts it, if it doesnt then im afraid you will have to buy a new screen. These can befound on ebay for a reasonable price.
I have written some guides on how to change your screens and how to disassemble the DS lite, these will guide youthrough the processes you need to take. These can be found by clicking on my name and then scrolling down to "tips and tricks", press the "view all" to see all of them and find what you need.
I hope this helps.
Regards,
SOD69
Jan 03, 2010 | Nintendo DS Lite
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
Wont turn on
I'll quote GBATemp here:
symptom:
the ds lite powers up for a brief instant, but then shuts off
potential solution:
disassemble the lower shell and check the connections of upper and lower displays (all three flexible cable connections).
You can view the full and detailed guide here:
http://gbatemp.net/index.php?showtopic=98240
GMAC
Jun 14, 2009 | Nintendo DS Lite Console
Nintendo DS lite
Baakie,
You turn de DS Lite on, the green light flashes and the unit turned of. Is that correct?
The DS Lite checks some things before he starts-up. One of these things are the screens. the DS sends a signal to it and expect an answer back. When this answer is not received, it shuts down.
The most common problem in these cases is the flatcable of the upper screen.
Question is, did you replaced the housing? If so, you might dammaged the flatcable of the upper screen. If not, the flatcable might be defective because of using the DS Lite a lot (open /close the unit).
So first check the flatcable of the upper screen (google and you will find manuals how to open the DS Lite but be carefull!!!!)
Second, on the mainboard are two fuses (F1 and F2) . Check these! One of them might be defective
Success
Jul 19, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Logo
138 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
