Question about Kenmore Elite 45986 Front Load Washer
F11 error does anyone know what an f11 error stands for
  • 8,197 Answers
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancell, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Good luck
Posted on Oct 05, 2009
How do I fix beeping F11 error code on my frigidaire stove?
The F11 error code stands is a shorted keypad. I suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for at least 5 minutes. If that does not work you may need to have a professional technician
Sep 28, 2016 | Frigidaire Stove/Oven/Range Black Glass...
Had power outage & when electric company put new transformer on, stove came on with this error f11 error, when open oven door it mesg goes off & on, oven wont work now
I appreciate your post, Katherine!
Based off the information you have provided your Frigidaire range is displaying an "F11" error code after a power outage. An "F11" error code stands for a shorted keypad. I would suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not work you may need to have a professional technician out to provide proper repairs. This will prevent you from any unnecessary part purchases. Hopefully this is helpful. -Matt
May 02, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
After a power outage, what is causing my Frigidaire stove to beep and display an F11 code?
Thank you for your inquiry, Katherine!
Based off the information you have provided your Frigidaire range is displaying an error code of "F11". An "F11" error code stands for a shorted keypad I would recommend performing a reset on your range. You can do that by flipping off the household circuit breaker for at least ten minutes. If that does not correct your issue it could be a possible problem with your EOC (Electronic Oven Control) or wiring harness. Hopefully this information is helpful for you. -Matt
Apr 23, 2015 | Frigidaire Kitchen Ranges
Frigidaire model number FEFL79DSB showing a F11 code on the control panel. Oven will not turn on and I am getting a alarm.
I appreciate your post, Dale Miller!
From what you have described your Frigidaire range is displaying an error code of "F11" and you are receiving an alarm. Normally an "F11" error code stands for a shorted keypad. I would suggest performing a reset and you can do that by flipping the household circuit breaker off for roughly ten minutes. If you restore power and continue to receive an "F11" error code you may need to replace your control panel. I would recommend having a professional do so, they will be able to properly disassemble your range and accurately replace the electrical component to not damage anything internally on your range. I hope this information is helpful to some degree. -Matt
Feb 28, 2015 | Frigidaire Kitchen Ranges
F11 error code
I appreciate the post, dan moore!
From the information you have provided your Frigidaire range is displaying an "F11" error code. Typically, the "F11" error code stands for a shorted keypad. This could be a false error code and the best way to clear any false error codes is to disconnect power from the range for at least ten minutes. If you continue to get an "F11" error code you may need to replace your EOC (Electronic Oven Control), I would recommend having a professional technician come out to properly replace any electrical component to avoid personal injury. Hope this information is helpful to some degree. -Matt
Dec 14, 2014 | Frigidaire Kitchen Ranges
HOW DO I GET TOO THE TROUBLE SHOOTING PAGE FOR A OVEN
Hello friend, thank you for your post!
I understand that you need troubleshooting steps for an "F11" error code. "F11" stands for a shorted keypad and one step for troubleshooting is to reset your range. You can reset your range by flipping the household circuit breaker off for ten minutes. If that does not help correct the "F11" code I would recommend you reach out to a professional for proper diagnosis because it could an issue with your EOC (Electronic Oven Control) or wiring harness. I hope this is helpful. -Matt
Sep 25, 2014 | Frigidaire Kitchen Ranges
F11 error on Electrolux gas range. How to reset
Hey friend, thanks for your post!
An "F11" typically stands for a shorted keypad. You can reset your appliance by unplugging it or disconnecting power for ten minutes. If you perform this step and continue to receive an "F11" it could be an issue within your EOC (Electronic Oven Control) and I would recommend having a professional come out to properly diagnose your range. -Matt
Sep 18, 2014 | Kitchen Ranges
F11 flashing kenmore he washer
The F11 error code indicates a serial communication failure. This happens when the 2 main control boards are unable to communicate with each other. This is either caused by a loose wiring harness connection or one of the control boards is defective. Good luck and please rate FixYa!
Dec 28, 2008 | Kenmore Elite 45986 Front Load Washer
Could you tell me what F11 code means?
F11 error code means there is a problem with the Control panel. Could be melted wiring, etc, since you left the oven standing. However, you can try unplugging the device from the power socket for about 5 minutes and reconnect. If the error goes away, then well and good; if not, you may have to replace the panel control.
Oct 13, 2008 | Frigidaire Kitchen Ranges
Error F11
Plug off the wall. Shaking & vibration of your washer causes circuit board connections to become loose; due to faulty manufacture. Remove the 3 or 4 screws from the back & take off the top cover to secure the connections, make sure they are tight. This applies for the F11 & F dl codes. Works for certain machines, dont see why it wont for yours.
Dec 10, 2007 | Kenmore 46462 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
157 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
