Question about HP Pavilion dv9700t Notebook PC
Loaded two patches from HP. One to deal with a printer timeout issue and second to ???Screen went to geo pattern. Forced shutdown. Now tries to reboot, blue lights flash go out and flash again every 3 secs or so.
  • 788 Answers
Remove the battery and disconnect from power source.
Disconnect any USB or external devices.
Remove the hard drive and memory. Disconnect the CMOS battery in the memory compartment.
Flip unit over and hold power button for 30 seconds.
Re-install memory and hard drive.
re-connect your CMOS battery.
Power up unit without battery installed.
Boot into safe mode.
Go to a command prompt.( start, programs . Acc. , dos prompt or command prompt.)
and type chkdsk /f
You will get a message that says can't run know but would you like to run a next bootup ? Say yes.and and type exit.
Next, reboot unit.
Hope this works for you.
Posted on Oct 05, 2009
HP LaserJet 2840 quit working when we were installing firmware update and power to building went off for a few seconds.
firmware corruption issue you will need to remove that printer from computer screen then reinstall it
then do firmware installation pre upgrade to stabilize(use cd or download of older version of firmware
once that's done then try the update again which won't work if old firmware is corrupted
May 17, 2012 | HP LaserJet 2840 Printer
My screen doesn't work, it is sleeping. What can I do ? After I took a rest my screen dit nothing. Whatever I trie, it doesn.t light up.
Try restarting your computer, If it happens again, try to find a pattern in the problem. If you can't restart, hold down the power button for a few seconds to do a forced shutdown.
May 12, 2011 | Acer Aspire One PC Notebook
My printer is hooked up ok I assume
first i would want to know if you use vista as an os? i would only be guessing without more info. if you use vista they have a patch to keep the drivers ffrom uninstalling themselves. you can get this patch at hp.com. i would down load this patch to your desktop uninstall all hp software the reinstall it. immediately when the install is done double click the patch file. i had this problem with a 7410
May 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
Message ID . . . . . . : CPA403D Severity . . . . . . . : 99 Message type . . . . . : Inquiry Date sent . . . . . . : 12/11/08 Time sent . . . . . . : 15:13:47 Message . . . . : Operator action required on...
This is a JetDirect error and can be cured by adjusting the IO and Idle timeout values. Set the IO Timeout (or Job Timeout) to 300 seconds ( 5 minutes) and set the Idle Timeout to somewhere between 900 seconds (15 minutes) and 3600 seconds (1 hour). Setting the IO Timeout (or Job Timeout) and Idle Timeout to 0 does not disable them. It causes the printer and/or print server to timeout immediately. The IO Timeout can typically be set through the control panel on the printer, or it can be set using the HP JetAdmin Utility. The Idle Timeout can be set by TELNETing to the TCP/IP address for the printer, or it can be set using the HP JetAdmin Utility. The HP JetAdmin Utility can be downloaded from HP's Web site, www.hp.com.
The print job is defaulting to tray 1 so you will need to change this at the application and printer driver admin and not at the printer itself.
Dec 11, 2008 | HP LaserJet P4014n Printer
Evo N610c Laptop. I get an attempt to start and an immediate shutdown every
can u get in bios remve all power then plug back in not off battery use direct plug defult new bios f1 f2 f11 ect
Oct 07, 2008 | HP Compaq Evo n610c Notebook
Scan function on HP6110 all-in-one printer won't work
See this link on HP's web site for a possible solution:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-46104-1&lc=en&cc=us&dlc=en&product=79477&os=228&lang=en
Jun 26, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP 6310 Cartridge Error: Replace Cartridge
well..did the printer cartridges come from HP?
May 23, 2008 | Office Equipment & Supplies
Hp 2575 printer
Hi, I have a good news that this issue can be easily solved and HP has released a patch to fix the issue. Just download and install the patch below: =========== http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-54112-1&cc=us&lc=en&dlc=en&product=1153494&dlc=en&lang=en ============ IN the download page click on the download only button and save the patch to the computer and then install it to the computer in network that you are facing the issue with.. Once the patch is installed try to add the printer by searching it in network and then the issue will be resolved. Hope this will work for you. Regards Barret.
Sep 01, 2007 | HP Photosmart 2575 All-In-One InkJet...
Open Questions:
HP Pavilion dv9700t Notebook PC Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
