Question about Brother MFC 210C All-In-One InkJet Printer
One colour does not come throughhave used new ink ,have set it to
One colour does not come through,new ink,set it to clean many times.seems to be plugged;otherwise works welldanie from canada
    Sergeant:
  • 195 Answers
Check printer properties settings....
Posted on Oct 05, 2009
Anything I print looks really faded.
Did you clean the print heads and/or re-calibrate the printer after installling the new ink. It is possible, however, to have gotten a faulty cartridge.
Hope this helps
Randy
Aug 31, 2012 | Canon PIXMA MP160 All-In-One InkJet...
I have installed new HP cartridges (black and colour)but on testing I get no colours except magenta violet and red!! Peter Fairclough
You must set to clean the print head. Yellow ink doesn't work. Try to clean the print head with some hot water, untill you'll see yellow ink came out. Time to time you must print some color files do not dry the ink.
Mar 31, 2011 | Office Equipment & Supplies
Black ink seems to be clogged even after putting in a new cartridge.
Try thi:
Cleaning the Print Head
  1. Press the Ink, Ink/Reports, Ink Management/Reports or Ink Management key.
  2. Use the up or down navigation key to select CLEANING.
  3. Press Menu/Set to confirm your choice.
  4. Use the up or down navigation key to select the color that is not printing
    -OR-
    Select ALL if more than one color is not printing.
  5. Press Menu/Set to confirm you choice.
  6. The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time.
  7. Test by printing the "Print Quality Check Sheet":
    2. Use the up or down navigation key to select TEST PRINT.
    4. Use the up or down navigation key to select PRINT QUALITY.
    5. Press Menu/Set to confirm your choice. Press the Color(Colour) Start key to print the Test Sheet.
If one or more of the ink colors is still missing from the printed page, repeat the print head cleaning steps listed above up to 4 more times. After each cleaning, print the Print Quality Check Sheet to see if there is any improvement.
Jan 17, 2011 | Brother MFC-5840CN All-In-One InkJet...
It is printing everything with a green tint and I had not changed any settings. I have also gone out and bought two new ink cartridges thinking maybe the new one I had was defective. There is no change...
I have personally encountered similar problem in my work. There is no problem with your printer.
Sometimes when either of the inks overflow at the nozzle, it gets absorbed to an extent into another ink compartment. So that colour affected now prints another colour; the colour that has crept into its compartment, Sometimes it is serious at other times is not. If not serious, usually, after a few solid colour prints the colour affected returns to normal.
I do not know how much of a technical person you are, but I will give you the solution to returning your colours from green the right colour. Bring out your colour cartridge. Peel off the seal covering top of the ink cartridge. You will see the holes through which in is fed into it. Get a clean handkerchief, fold it and place over the top of the cartridge. Hold it over a bowl or something. Now place your mouth over the top with the handkerchief in between and blow hard. Ink will discharged at the nozzle. Clean off the ink. (At the nozzle do not rub only dab). Now press a piece of folded tissue to the nozzle firmly. It should be blotted with ink:- red, blue, yellow. If any colour is missing you may need to repeat the procedure. Once you get the three colours back, the issue is resolved.
Dec 21, 2009 | Kodak ESP 5 Printer
No colour printing
The problem with Canon printers sometimes is that, if you do not use original cartridges and put compatible ones, the printer will not recognise them. Even if you refill the originl ones the printer will still think that they are empty due to the microchip that every cartridge has. Try using original inks. If you already used original inks, then another reason might that the ink tubes have benn blocked because of dried ink if you haven't used your printer for a long time. Try performing a deep clean through the printer application.
Hope that helps
Apr 20, 2008 | Canon i80 InkJet Printer
Wont printer color
was the colour ink printing verywell before you change it? go to your printer properties setting if your printer monochrome setting is on.well remove your ink & use a soft tissue to clean your printer ink cup softly & clean the ink terminals (contacts)too. use a soft tissue on he ink nozzle if the three colour appeare on the tissue .then install back & run a self test if the test prints colour , then you can reinstall your printer & run a testpage.
thanks.
Mar 31, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Printer seems to be leaking ink?
take those out are uusing off brand ink
Feb 03, 2008 | HP PSC 1510 All-In-One InkJet Printer
Some colours not printing
I bet you are using non genuine ink, the MP780 will not put up with that ink, you will need a new printhead and maybe a purge unit. Take the machine to your ink supplier and get him to fix it as he supplied the ink
Jan 29, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Will not print some colours
Rhis seems to be a printer Firmware problem, Nothing for it but to bin the printer and start again.
Nov 13, 2006 | Canon BubbleJet i9950 InkJet Photo Printer
Brother MFC 210C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
