Question about Hoover F7431-900 SteamVac Vacuum
I can't find the clear replacement part on the front of the hooverf7431-900
    Scholar:
  • 190 Answers
Are you looking to replace the clear recovery nozzle?
The phone number of the company is (440) 996-2000
Posted on Oct 05, 2009
When the shampooer is moved forward to initially to spray the shampoo the plastic guard on the front drags the floor and keeps it from moving forward and shampooing. .
The one's I've used the sprayer is on the back of the suction (suction hood which is kind of clear plastic), you watch that clear part to see if it is picking up dirty water. Recall it's easier to pull it and if caught just push down on handles and that raises front of machine to clear carpet snag. I would walk backward as it sprayed and then picked up the water with dirt. If different machine you could spray moving backward, go back to same starting point go again and don't spray but just hold it near carpet so it picks up the water.
Jun 03, 2016 | Bissell ProHeat Pet Upright Deep Cleaner,...
How can I remove the floor nozzle window to clean it?
There are 2 screws in the front corners of the nozzle. Take those out and pull upward. There are 2 tabs on the back of the clear nozzle cover over the inlet that will snap out when you lift the front. Be very careful when replacing the screws. They are prone to strip the plastic if you over tighten them. Also make sure the seal is clean and back inplace before putting it back together.
Jun 02, 2015 | Bissell 8910 ProHeat Clear View Upright...
Machine will not go forward
That clear cover you have to put properly. In the midlle you have small noch that needs to be engadged (locket).Try to slide front clear cover on the base and don't forget to put 2 screws
Dec 01, 2014 | Bissell Proheat Upright Carpet Cleaner...
I just ordered/received the filter apparatus that attaches to the clear plastic canister, BUT I can't seem to remove it.
The filters on a Dyson DC07 dont go inside the clear bin. There are 2 filters in this machine the first which is your washable filter is on the lower right side of the vacuum, if your facing the front of the vacuum. to remove this filter you push on the purple fiter catch button and lift up on that filter area then your filter will be in there. the only other filter is your permanate Hepa filter. which sits under neath the clear bin assy but that should almost never be removed. if you do need to the are 3 spots on the gray plastic lid. you take a flat head screw driver and gently slide it in the slots starting with the sides and then moving to the one in the middle in the front and then you just get under the lip and pop it up. and then you can access that filter. but again that is a permanate filter. it should not have to be replaced. and it can never be washed.
Sep 19, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
Remove bottom of electrolux prolux upright vacuum. Hose is clogged.
You shouldn't have to remove disassemble the powerhead.
Lay vacuum on it's front. Between the tank and the powerhead is a black flex hose. Pull the end straight out from the powerhead. Then unscrew the tube from the tank using a clockwise turn. Remove the tube and visually check for clogs and splits. Clear or replace as needed.
If there's a clog in the powerhead behind the brush, this can be cleared using a wooden spoon handle or similar object.
If there's no clog in either place, there's a couple other possibilities. First, turn the vacuum back upright, open the hose flap, turn vacuum on, and place hand over opening to check for suction.
If there's a lack of suction, the bag needs replaced, the afterfilter beneath the bag needs cleaned, or the motor needs replaced.
If there is suction, put a coin in the opening inside the port and to the right as you're viewing the front of the vacuum. The coin should drop to the floor. A clog in thes section is unusual, but can happen.
If there is still no suction, take the vacuum to the nearest authorized Aerus Electrolux store for free diagnosis.
http://www.aerushome.com/storelocator/
Mar 11, 2011 | Electrolux Vacuums
Replace pump
Six (6) on board/top screws approx. Two (2) in front near nozzle area and four (4) under water resevoir tank. Engage handle release and lie handle down on floor and take out screws and save (of course) You will need to also unscrew clear water cap from top of on board unit and save and make certain you retain process to put back into position..(cap/spinner/small screen /pin up) Now you have access to the pump/motor, drive belts, etc. Unscrew appropriate screws and detach water lines and note replacement points. from pump near front right area of unit. Good luck!
Apr 30, 2010 | Bissell 8910 ProHeat Clear View Upright...
Pickup water
The clear shroud covering the front of "hood" has two sheet metal type screws at the bottom in front of the brushes, these two screws also hold the little straight brushes ( one on each side) in place. I found one of these screws had broken it's plastic "socket" and was no longer applying any pressure to the hood, this caused loss of suction and would not pick up any water...You can test this by applying a little pressure to the "clear hood" after you have applied water and shampoo. You should immediately see water entering the pickup reservoir container. I removed the broken plastic "socket" and replaced original screw with a longer wood/sheet metal screw. I think this is a weak point on the cleaner and is easily broken by catching the front lip on any hard object. Hope this helps
Aug 24, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Cleaning under floor nozzle window
make sure you removed the 2 screws closest to the front then lift up on the front end of the window sometimes its sticky but it will lift up. when putting it back on put the tabs on the back end in first then slip it down in the front , replace 2 screws
Jul 29, 2008 | Bissell 8910 ProHeat Clear View Upright...
No suction to retrieve water from carpet
The tank lid of your recovery tank is designed to engage two tabs to lock the front of the lid down on the seals. Look at the front corners of your recovery tank. You will see a tab extending out on each corner. These two tabs insert into the corresponding grooves in the lid. Once engaged, the lid folds down and the clip on the lid snaps into the back of the tank. When installed correctly, if you pull up on the front of the lid, it should NOT lift away from the tank. The front of the tank has a square "duct" that is removable for when the hose is inserted for furniture, etc. Make sure that this duct is replaced back into the tank when using on the carpet.
Jan 19, 2008 | Vacuums
Vacuums Logo
24 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
