Question about Sony FD Trinitron WEGA KV-36XBR800 36" TV
A frinds's grandson turned on the delay timer on her set. now she can't turn it on. how can she override it? She has trien the remote control and the manual buttons. She has unpluged it for up to 15 min. she says all that happens is the standby light blinks.
  • 115 Answers
Its not a problem ith any timer . That tv has no lock able to keep it from turning on. The tv is broken and the stby light is blinking a pattern indicating an error code. Probably six or seven blinks in a row maybe four. My guess is that it needs two regulator OSC I.C.s and a capacitor replaced. I think you should take it to a sony authorized servicer. Its a good model , worth repairing for no more than $250.00 or a little more if they'll pick it up and deliver it.
Posted on Oct 05, 2009
Hb51r manual
Plug in
make sure bulbs work
rotate dial to set choice of delay times
timer turns on at dusk,,, and delays off for amount of time you choose
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#outdoor
Gene
Dec 13, 2013 | Intermatic Outdoor Timer/Photo Control...
Timer delay
It seems like defective control panel
Dec 08, 2013 | Indesit Washing Machines
I am wanting to energize a relay for 3 min. then off, whether the power stay's on to coil or not! what I want to do is when a door rises and hits a switch I want to energize a coil for 3 min. whether...
You want 3 minute 'off delay' timer.
When timer is energized with push button or momentary electrical signal, circuit remains ON for set amount of time, and then turns OFF.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Aug 15, 2011 Dayton/ Grainger website is offline
Most delay timers have 1 amp capacity rating, so circuit needs fast acting 1 amp fuse, and timer controls separate relay or contactor unless Load is equal to 100 watt light bulb.
3-minute off delay pin timer
Omron shows 120Volt 8-pin M-series-(minute) 3 minute delay timer
Part number H3CR-H8L 120volt M
http://waterheatertimer.org/pdf/Omron-timers.pdf
Example 240Volt timer showing timer and base.
http://www.sourcingmap.com/ah33-220v-030-minutes-delay-timer-relay-socket-p-119441.html
Wiring diagram shows on side of timer.
Aug 15, 2011 | Amperite Dayton Solid State Timer On Delay...
My remote does not work, is there a test I can do or setting o My nikon 80
Set the camera's shooting mode to one of the remote modes. Quick-response remote fires the shutter when you press the button on the remote. Delayed remote gives you two seconds to hide the remote behind your back before firing the shutter.
Press and hold the shooting mode button (just to the right of the control panel on the top of the camera, marked with overlapping rectangles) and turn the main command dial (on the back) to cycle through the different shooting modes. The quick-response remote mode is represented by an icon of the remote control. The delayed remote mode is represented by the remote icon and the self-timer icon.
Jan 16, 2011 | Nikon ML-L3 Remote Control
How do I set timer
manual for HB51RC
http://www.intermatic.com/%7E/media/files/intermatic/products/instructions/timers/hb61rc%20-%20english.ashx
See timer at Amazon
http://www.amazon.com/Intermatic-HB61RC-Digital-Outdoor-Control/dp/B00004W4X5
Plug timer into outlet
Plug lights into timer
Timer turns on automatically at dusk + override lets timer run during daylight hours
Timing cycle repeats each 24 hours
Use selector button to set timer
Timer must be reset after power outage or after unplugging timer.
Rotate selector button and choose one of following
F > Lights are OFF
O > Constant ON
1 through 9 > timer turns ON at dusk and turns OFF 1 to 9 hours later
d > timer turns ON at dusk and OFF at Dawn
1. through 9. > timer turns ON immediately and then turns OFF 1 to 9 hours later
Maximum wattage 1000
50 mini-bulb-string of Christmas lights is 25 watts
Dec 14, 2010 | Intermatic Outdoor Timer/Photo Control...
New 220 timer put in ,wont turn on.Vsiual chek working and its keeping time,switches look good but woont kick on?
I wish I knew the model number.
maybe the wiring is wrong, but different model numbers have different wiring.
I wrote a page on each the T-104 and T-1906 240V timers:
It shows the wiring for 2 common Intermatic timers
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
http://waterheatertimer.org/How-to-wire-T1906-Intermatic-timer.html
Now let's troubleshoot a bit:
You say the dial is rotating around.
And the dial has tripper pins in place.
What about the manual override? Does the manual override turn lights on and off?
If manual override does not turn on the Load, then your wiring is suspect.
If manual override works, then your wiring could still be wrong by one wire.
Check your tripper pins.
Are they attached and set exactly right?
Are you using both ON trippers and OFF trippers?
1565897.jpgThe OFF tripper pushes a lever. The lever is connected to Manual override. Click manual override to see if timer can turn Load ON-and-OFF
Up-vote if this information helped. Thanks for the feedback.
Oct 14, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
How to use nikon ML-L3
To set the D90's shooting mode, press the shooting mode button (the overlapping rectangles to the right of the LCD panel on the top of the body) and turn the main command wheel on the back. Quick-response remote shows a picture of the remote control unit, the delayed remote shows that and the clock (the same symbol used for the self-timer).
The remote mode is cleared whenever the camera is turned off. Since monitoring the infrared port consumes battery power, the camera may turn itself off before you take a shot. To prevent this, change custom setting #C5 to something more appropriate.
Oct 11, 2010 | Nikon D90 Digital Camera with 18-105mm...
Inadvertanly set delay and can't figure out how to get it back to the original setting.
Repeatedly press the shooting mode button on the upper-right side of the camera (marked with overlapping rectangles) to select the desired shooting mode. If that doesn't work, hold down the button and turn the main command dial (on the back) to cycle through the modes.
The available modes are Single frame (letter "S" in a rectangle), Continuous (overlapping rectangles), Self-timer (one-armed clock), Delayed remote (self-timer above remote), and Quick-response remote (remote).
Jul 30, 2010 | Nikon D80 Digital Camera with 18-135mm...
Setting
manual for HB51RC
See timer at Amazon
Push selector button and choose one of following
F > Lights are OFF
O > Constant ON
Oct 02, 2009 | Intermatic Outdoor Timer/Photo Control...
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
Sony FD Trinitron WEGA KV-36XBR800 36" TV Logo
171 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
