Maytag MMV4205 1150 Watts Microwave Oven
Problem for Maytag MMV4205 1150 Watts Microwave Oven
Maytag Over The Range Microwave: Melted glass turntable, rollers
By baboudreau on Oct 05, 2009
Same problem here. We think a family friend was operating the microwave, went to use it later and found the round glass platter with a hole melted in it and the turntable ring melted in the same place near one of the wheels. Recall?
Solution #1
posted on Oct 05, 2009
Not Rated)
milleraba
Rank: Wiz  Maytag Kitchen Appliances  Expert
Rating: 83%, 456 votes
Considering the melting pooint of glass ...
Normally, microwave travels around round surfaces (Look at the B-1 for example) If you put flat metal in a microwave, you will create sparks ... lots of em. Is it possible you have something going on with one of the wheels ... like a piece of tin foil?
At a minimum, I think id be inspecting everything inside very carefully and then give it a good cleaning.
You might want a pro in your area tale a look at this as well.
a
Was this helpful?
Yes
No
Popular Solutions for Maytag MMV4205 1150 Watts
Questions and Unsolved Problems for Maytag MMV4205 1150 Watts
Do you recommend Maytag MMV4205 1150 Watts Microwave Oven?
Answer
Answer
I mistakenly used the "cook time" instead of timer, and cooked for 22 minutes with an... (More)
Answer
If I use the High setting, it trips my fuse box. I seem to need a lower setting (5) for recipes that... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Maytag MMV4205 1150 Watts...:
Top Microwave Oven Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Microwave Oven Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
