Question about Kitchen Ranges
GAS RANGE OVEN DOES NOT WORK
I HAVE A FRIGIDAIRE GAS RANGE ,THE OVEN IGNITER COMES ON BUT THE OVE DOES NOT COME ON EVEN GAS IS ON . DO I NEED A NEW IGNITER ?
    President:
  • 1,304 Answers
If it worked before and not new, i would say yes,
if its only glowing orange it needs to be replaced
it should get almost white hot
Posted on Oct 06, 2009
Ove burner
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
May 21, 2010 | Tappan TGF657 Gas Kitchen Range
Top burners on Frigidaire gas stove come on but the oven will not.Whats the problem?
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 30, 2010 | Frigidaire FGF326AS Gas Kitchen Range
Frigidaire oven wont ignite
Jan 29, 2010 | Frigidaire FGF378AC Gas Kitchen Range
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Older frigedaire range oven quit working
the problem is in the ignitor it is not pulling enough amps to open the safety gas valve even though it glows doesnt mean it is good
Jan 07, 2009 | Frigidaire FGF378AC Gas Kitchen Range
Oven
In many cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. (It's the igniter that actually controls the gas valve) The igniter has probably gone bad. ($50.00 to $90.00 for igniter)
Jun 09, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Frigidaire lp gas oven
YOUR OVEN GLOW IG NITER IS SUPPOSE TO STAY ON THAT'S NORMAL. WHAT YOU NEED TO DO IS CHANGE THE ORIFICES ON YOUR OVEN VALVE BECAUSE YOUR USING LP GAS MOST OVENS COME NEW SET UP FOR NATURAL GAS ALL OF THEM EVEN YOUR COOKTOP
ALSO
May 22, 2008 | Frigidaire FGF376 Gas Kitchen Range
Oven not always working
MOre than likely your igniter is getting weak. If it doesnt pull enough amperage. it shouldnt let gas into the oven. If it is letting in gas and not igniting, I would suggest a new igniter and a new safety valve. Hope this helps!
Nov 22, 2006 | Tappan TGF320 Gas Kitchen Range
Kitchen Ranges Logo
111 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
