Question about Maytag PYE2300AY Electric Dryer
Maytag Dryer MED6600TQO will not cycle, all the lights come on but no movement
  • 4 more comments
  • chitojr Oct 05, 2009
    It's an all digital display, with one knob to select cycles, everything else is push button for time, temp level, etc. Still think it's the timer, if so can you provide part #
    Maytag Dryer MED6600TQO, all digital display, when start button activated, nothing occurs, just the lights turned on, no movement
    door clicks shut, no cycle, lights on, timer activated no movement
    already open just need to know what part to change
    Thank U for your help, u gave me the correct answer. As far as roniecon, your other expert, fire him he's clueless
    roniecon, was wrong protek480 was correct on the second try, dissatisfied with your serve, waste of twelve dollars, which is what it will cost me for the part I need to replace, never use your site again
    President:
  • 1,714 Answers
First thing to do is check the door switch. Poke something in there and make sure you h ear it 'click'.
Posted on Oct 05, 2009
  • Craig Butler
    Craig Butler Oct 05, 2009
    Sounds like a 'thermal fuse, when that blows, nothing will start. It's not a big deal to change. Do you have any electrical/mechanical skills? Can you open it up?
  • 6,826 Answers
If the timmer is not any good ,this would be the problem.Is this all digital?Or does it have a turn type mode selector?If it has the turn type selector,that is the timmer.The timmer has gone out.You can order the part,and replace it yourself.Just by removing the back,or the control top housing.I hope this was helpfull.
How do I fix my maytag dryer
sounds like its hung in a loop unplug wait a few min. plug back in
Dec 14, 2015 | Maytag Neptune MDE5500AY Electric Dryer
Maytag electric dryer, lights flash, chirping
I had this happen with a maytag washing machine. The repair guy replaced a board and it worked fine. I'm afraid that's what happened here.
Nov 13, 2012 | Maytag Dryers
Maytag dryer epicz says "controls
controls locked
This feature allows you to lock your settings to prevent
unintended use of the dryer. You can also use the Control Locked
feature to prevent unintended cycle or option changes during
dryer operation.
To enable the Control Locked feature:
Press and hold AUTO DRY LEVEL for 3 seconds. Control Locked
glows and a single beep tone is heard. To unlock, press and hold
AUTO DRY LEVEL for 3 seconds. The indicator light turns off.
Jul 15, 2011 | Kenmore Elite HE4 Electric Dryer
Dryer will turn on and count down but will not start to spin or heat up, model med6600tqo
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 28, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
I have a maytag dryer that all lights are functioning but unit will not begin a drying cycle.
REPLACE THERMAL FUSE ON DRYER HEATER DUCT .... GO TO SEARS.COM THEN PARTS DIRECT ENTER YOUR MODEL NUMBER AND SHOW YOY PARTS DIAGRAM AND LOCATION PART 4A
Jan 26, 2011 | Maytag SDE2606A Electric Dryer
Our dryer stopped working mid cycle. light
with no light it tells me you have lost L1 check your outlet, and your wire connections
Sep 30, 2009 | Maytag HYE3658AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
59 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
