VERY NOISY WHEN SPINNING WITH EVEN AND LIGHT LOADS
WASH IS VERY NOISY WHEN IN SPIN MODE WITH EVEN AND LIGHT LOADS
    Problem Solver:
  • 5 Answers
It is more than likely not level... put a level on the top north to south and east to west... adjust the legs by turning them to lower or higher the legs
Posted on Oct 05, 2009
My beko wmb61431s will work in spin or rinse mode
check the clutch, the belt, the motor coupler, the door switch,
Feb 25, 2015 | Beko Washing Machines
Washer will not spin agitated slow GE WJRR4170G1WW
Dawn, sounds like your lid switch may have gone bad. Just a guess. There is a place called repair clinic that has some videos of how things work. Check that out and see what you think. You may need to repost your problem if that doesn'rt help you any.
Mar 21, 2014 | Washing Machines
Wash machine model mav 7600, started making tremendous noise, first in spin cycle only and then in wash cycle also. After running a few loads with the noise the machine just stoped running....
This sounds like collapsed/broken drum bearings. Check for movement between inner and outer drum. Also rotating the drum by hand will be hard (or immpossible), and noisy. It could be the motor and belt, but most times it is bearings.
Aug 11, 2010 | Maytag Washing Machines
Washer making noise when on spin mode
Washer may not be level.
Loads may be too large.
Sometimes a smaller load will send all of the clothes to one side and it may make a pounding noise.
Check to make sure that your machine is level, then wash a smaller load to start and then wash a larger load. Good luck!
Jan 26, 2010 | Washing Machines
Water on floor; small amount to begin with..15 loads ago?, now lots of water (1+ gallon) and black grease on floor. slow spin, noisy and hard to get spinning.
if this machine is an older model, it may not be worth the effort to get it repaired. This sounds like the transmission and spin tube are on the way out, and there is some seeping around those seals. The transmission is probably leaking and will soon fail.
Aug 31, 2009 | Washing Machines
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Whirlpool Ultimate Care II Model #LSQ7030KQ0 Won't Spin
Either a bad lid switch or a bad clutch/brake on the transmission.
Jun 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool top load wash machine does not spin
Check your lid switch it may be bad.
Mar 18, 2009 | Washing Machines
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
Washing Machines Logo
117 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
