Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega 32-5yrs-olf goes to a red background and turns off
If you immediately turn it on again, red background persists. 5min later it turns off. Let set for 1/2 hour and color comes back until it seems to heat up again. Any thoughts?
Jim L.
  • 736 Answers
Hello jim .. that could be a short from grid to cathode in the picture tube ..usually thats just a loose flake of phospher and can be knocked out with a special electrical gadget .. sometimes called a cathode beamer .. some times we used to use a charged capacitor to knock out the short .. not sure if anyone does that anymore .. sometimes you can kick loose the particle by tapping on the neck of the CRT with a plastic screw driver handle (not hard) .. there is another possibility .. on the back of the CRT is an electronic circuit board .. there are three larger transistors that drive each gun ... be careful because there is about 300 volts on those transistors ... but if you touch each one you might find one that is cool .. the others will be hot or luke warm .. the cool one is likely shorted (if your screen goes to bright red) ... that will give you full brightness on that color .. so yours would be the transistor for the red gun ... once in a while there is a bad IC on the main board that drives those high voltage transistors also a bad solder connection is seen once in a while ... a volt meter or scope would quickly narrow down the possibilities .. since the problem is thermally related then you might be able to pinpoint the part by using freeze spray to cool one part at a time ... sorry this is so technical but its a technical problem .it would take a good tv shop only a few minutes to zero in on the problem but they charge so much anymore that its a risk unless you have an agrement on estimate beforhand . ..
Posted on Oct 05, 2009
Sony TV turns off immediately after turning on
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. Check this link to get more details about Sony Blinking codes.
Jan 13, 2013 | Sony FD Trinitron WEGA KV-20FS100 20" TV
My Sony wega tv won't turn on goes into standby red light blinks 10 times then shuts off?
Look at the owner manual as the 10 blinks is a error code or Google the model number to locate that information--Sony error codes are general and often misleading.
I would if looking at the set inspect the lamp first.
Aug 28, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a sony wega trinitron, when the tv is turned on, (no visual, or sound) the red stand by light blinks 7 times, and you hear the tv click off? Please help
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Jun 06, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Comes on and later goes blank
How much later? The Sony sets have a setting in the menu that turnes the TV off if there isnt' any input, Sometimes this feature gets messed up, and the feature has to be turned off, Check that out and see if that takes care of the problem.
Oct 01, 2009 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Picture and sound first turn on before disappearing over and over again.
Symptom shows its weak Lamp problem in TV and you need to replace lamp. Replacement procedure is easy and written in instruction manual of TV.
Always buy Sony Original Lamp from Sony Accessories for longer life of TV.
Apr 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony wega kv-36hs20 will not turn on
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Mar 02, 2009 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
74 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
