Question about Xerox XG-91D 19" LCD Monitor
My xerox lcd monitor is not working the power button is not lighting up
I turned off my computer and when I turned it on again my xerox lcd monitor power button does not light or flashand i am getting a blank screen does t his mean that the monitor is not working and I shall have to .replace it wlawrie44@yahoo.co.uk.
  • Anonymous Apr 06, 2008
    THE LIGHT ON THE MONITOR TURNS ON AND GREEN BUT, THERE IS NO PICTURE. I BOUGHT A POWER CORD IT IS 12 VOLTS 1.5 AMPS AND THE FACTORY CORD SAYS 12 VOLTS 2.5 AMPS COULD THIS BE THE PROBLEM? THANK YOU, CAROL SHUGARS cshgrs@aol.com
  • 383 Answers
Computer Post / Beep codes The computer POST (Power On Self Test) tests the computer, insuring that it meets the necessary system requirements and that all hardware is working
POST troubleshooting steps. then this issue is not a NO POST but is an power related issue see document ... For users who are more comfortable working with the inside of their computer.
Good Luck, Please dont for get to Vote/Thank You.
Posted on Dec 22, 2007
Monitor will not light up
Some capacitors looking flat are blown off inside. (Should check largeest one too)
Use a tester to check the, again, first.
If you can see light on power button (some do), then should replace main board.
However, if monitor use a power supply looking an adapter type like laptop, check it also in case.
Jun 21, 2013 | Xerox XG-91D 19" LCD Monitor
My 19" TFT LCD monitor
Power capacitor problem, needs taking to a qualified TV repairshop to have the capacitor replaced / checked
Dec 28, 2010 | Xerox XA7-192i 19" LCD Monitor
LCD Monitor will power in and when connects to modem the power button is green then turns orange, what is the problem?
When the monitor button turns to yellow that means the monitor is on standby mode. Try rebooting the the computer after you have connected it to your modem. If the light goes to yellow again check that the computer is on and that all the cables are connected properly. HP Computer monitors are a little confusing, Sometimes depressing the power button again while it is yellow will turn it on and should so green.
Jul 21, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Xerox computer monitor light keeps flashing
try swapping a known good monitor to make sure its the monitor?
http://www.aa1consulting.com
Jul 26, 2009 | Xerox XG-71D 17" Flat Panel LCD Monitor
Xerox XA7
ccfl tube is destroyed or fuse on inverter board
Sep 01, 2008 | Xerox XA7-192i 19" LCD Monitor
Xerox xa7 19" lcd monitor
That means that you have a defective inverter board.
The inverter is a small power board that power up the LCD backlight lamp, determining light intensity, when it is like that, the inverter is defective and must be replaced.
Nov 07, 2007 | Xerox XA7-172i 17" LCD Monitor
XG-91D (Black) 19 in. Flat Panel LCD Monitor
Partition shows up as a MS-DOS partition This utility is designed save information you may be working on when it goes into sleep mode or when your battery becomes low on power.
Computer questions and answers listing 700 - 800 CH000735, How do I disable the power, sleep, or wake buttons in Windows?
Good Luck, please dont for get to Vote, Thank You.
Aug 03, 2007 | Xerox XG-91D 19" LCD Monitor
Screen goes blank also.
I too have an LCD Xerox - it worked fine for a while, then kept going blank and going onto standby. Unplugging and reconnecting from both pc and power seems to reset it. It hadn't happened for months but started again the other night when it occurred to me that I had just downloaded MS security updates - I've removed the ones that I downloaded just before it started happening again and the problem seems to be solved. Hope this helps someone.
Dec 19, 2006 | Xerox XG-91D 19" LCD Monitor
Xerox XG-91D 19" LCD Monitor Logo
172 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
matt
matt
k24674
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
