Question about Dryers
I changed my dryer power chord from 4 to 6 feet. I have all the correct wires hooked up. There is a pigtail coming off the dryer power bar. As a result, I have this loose white wire flopping around. My dryer engages for about a second, but then cancels all power, and the display goes dark. Help!
    President:
  • 1,714 Answers
That wire flopping around is probably the ground wire and needs to be hooked up, it's probably grounding out the power for the control.
Posted on Oct 05, 2009
Can you change a four prong pigtail with a three prong pigtail on a whirlpool duet dryer
Yes, you surely can!
Here's how.
When you open up the back of the machine where the electric cord attaches, you will see a row of 3 screws/bolts.
Your 4 wire cord has the black wire going to one of those screw/bolts. That is a HOT connection.
Your cord also has a red wire attached to a screw/bolt. It too is HOT.
These two hot connections are the outside two of the row of three screws/bolts.
The one in the middle is a ground wire, and is white.
The other, the fourth wire, usually blue or green, it is attached directly to the sheet metal of the dryer itself.
It too is ground..
Now, the 3 wire cord is not color coded, it is "position" coded.
The two outside wires go to the outside (in the row of 3) screw/bolts of the dryer. the middle wire is hooked to the middle ground screw.
It doesn't matter whether the outside wires go to the right screw or the left screw, but never to the middle screw.
By the same token, never hook the middle wire to an outside screw/bolt.
You will have no fourth wire going to the sheet metal.
Be blessed.
Apr 16, 2013 | Dryers
TED8740PQ0 ESTATE DRYER WON'T START.
First, take a look at this video to be sure the plug is correctly installed. Be sure to unplug the unit before making any changes! Post back your results.
Nov 17, 2012 | Dryers
I had to change my plug from a three prong to a four now i get a light on the inside but cant get the power to come on and its hooked up correctly
check the voltage at the outlet, and then the back of the dryer where it is pigtailed in, if it is all correct then you will need to take the top off the backside of the panel and there should be a diagram in there, then trace the flow of the voltage. Hope this helps Tim
Apr 18, 2011 | LG DLE1310 Electric Dryer
Changing pigtail to 4 prong. What do you do with white wire coming out of dryer?
The following link explains, in detail, how to correctly wire a power cord to an electric dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Pay particular difference to the 3 and 4-wire configurations. There is a difference in how the neutral and ground wires are terminated.
In a 4-wire configuration, match the corresponding colors (RED, BLACK, WHITE) at the terminal block. The ground wire (GREEN or bare copper) will be terminated separately on a ground lug on the equipment cabinet. DO NOT connect the ground and neutral together.
If you have questions, please post back and let me know. I receive email notifications to all your comments and/or questions. I hope this helps you.
Apr 21, 2010 | Kenmore 600 7962 Dryer
Need to change cord to three prong from four...they are not color coded, does is matter how you hook them up
The wires on a flat 3 prong pigtail go on just as they are. The center wire goes on the center post. The outer wires go on the outer posts. The wires do NOT crossover at all and it doesn't matter with the outer wires. Just as long as the center wire is on the center post. You *must* put a ground strap from the center post to the case. It should have been removed or disconnected when the 4 wire pigtail installed. If you have a round 3 wire pigtail, the White wire goes to the center post. Red or black to either outer post.
Jan 02, 2010 | Frigidaire Electric Dryer
I have a 4 ring power chord..how do i hook it up
well the red and black are the hots, they go on the 2 outside terminals. the center terminal is the neutral for the white, the green should go to a good nearby chassis ground..
hope this helps,
best of luck,
ttfn
Oct 29, 2009 | Whirlpool GEW9250 Electric Dryer
I just bought a used amana dryer that is 1 year old. it has a 3 wire pigtail and i have a 4 wire plug in and need to change out the pigtail. need some direction on if possible to change it out or will i...
go to the local hardware store and buy the male plug for the female plug that you have in the wall just hook up the three plugh in place of the 4 wire plug. The 4 wire has a netural and a ground which is the same thing and two 110 hot wires that are 110 v each, hook up the copper colored wires to the copper colered wires and the one ground on silver. screw or white to silver wire. this is Ground you only need one ground and if the plug on the wall is three prong it is go to use a three wire plug the third wire is for a backup ground on new systems
Oct 04, 2009 | Amana NDE2330AY Electric Dryer
Need to change dryer pigtail
3 wires, black and red goto either side, and the white goes to the center terminal , if you have a green(ground) that attaches on the body of unit itself
Dec 07, 2008 | Dryers
Dryers Logo
159 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
