Question about Broan-NuTone QT80 Fan
My fan doesn't start right away when the switch is turned on. Then as it is starting up it squeaks and hesitates. Seems like a "gunked-up" problem but I can't remove the impeller blade assembly from the motor shaft. Any suggestions?
    Scholar:
  • 95 Answers
The fan blade can be removed from the shaft. You just need to pop the lock washer off and pry the fan blade. You most likely will not be able to remove the fan blade without damaging the blade. You can buy the replacement fan blades online. The part number is 5901A000. Here is a blog on the entire replacement motor assembly. http://nutoneproducts.typepad.com/nutone-products/2009/08/nutone-0695b000-replacement-bath-fan-motor-for-model-qt80.html
Posted on Oct 08, 2009
Kenmore 22 porcelain plus
Will you can not lubricat fan motor you will have to replace it because it will just keep doing it right on that is the only way you can fix it.
May 01, 2014 | Refrigerators
When i start the car it makes a squeaking sound, also the fan doesn't come on it is suppose to come on when you start the car or turn on the ac the fan doesn't come on.
could be the clutch fan if your fan doesn't come on. also the belts could be to tight or the alternator belt. good luck.
Mar 23, 2013 | 2001 Hyundai Sonata
Squeaking noise coming when car starts and turning right?
The fact that it happens when turning would lead me to believe that it is the power steering belt. Check your belts for tension, cracks, glazed and any other condition that would warrant replacement. If to much deflection when checking the belts at the longest stretch of belt adjust the belt.
Jan 20, 2013 | 1996 Jeep Cherokee Sport
Car tries to start but cant seem to turn over. battery seems fine
Get your battery tested, if your battery has failed internally sometimes jump starting doesn't help as the battery is pulling all the current away from your starter.
Mar 08, 2012 | 2000 Jeep Grand Cherokee
Terrible squeak when started seems to last longer with the a/c on & squeaks during turns but will go away after a few turns. Have also noticed at times it makes it difficult to turn & the battery...
sounds like your serpentine belt is getting old and needs replaced they squeel wheel get stretched with age like a 50 dollar replacement doing it your self
Sep 12, 2010 | 2004 Hyundai Elantra
Heavy squeak when turning(like turning heavy rubber belt)Tribute
Your fan belt is slipping. As you turn the wheel you make a power demand on the power steering compressor. This compressor takes its power from the fan belt so as you steer the compressor shaft is harder to rotate and the belt slips as a result. The fan belt should be adjustable by loosening the alternator bolts and moving the alternator away form the engine and than re-tightening the bolts. Check that the fan belt is not worn, if there are obvious signs of wear or cracking then renewal would be the best step. Always make a sketch of the path of the belt around the respective engine pulleys before removing it.
May 14, 2010 | 2001 Ford Escape
Intermitent Starting Problem
it sounds to me like you have a loose alternator belt also check the belt for cracks that is an indication of a worn belt and or dirty battery cables if your battery is more than 3 yrs old it may need to be replaced they normally only last about 3 yrs depending on the climate
Mar 14, 2010 | 1997 Plymouth Neon
92 Buick LeSabre overheating.
make sure the cooling fans are working and most vehicles will turn on the fans when you first start and A/c is in max mode
Apr 24, 2009 | 1994 Buick LeSabre
Broan-NuTone QT80 Fan Logo
686 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
Craig Dupler
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
